Usually there is a hole in close to the cd slot, where a pin can be inserted in order to push out a cd manually or a similar manual override.
Which CD player/ radio are you using?
The only way to get the cassette out is to take the radio out and take it apart. The 'eject' mechanism has malfunctioned and will not allow you to remove the cassette normally.... SORRY!
Turn the radio off first and then disconnect the battery for 2 min then reconnect the battery. This should reset your radio and then you can eject your CD, and reset your stations and clock. Good luck
Generally on most multi disc changers, if you hold the eject button for 5-10 seconds it will force eject the holder. Try that. If not, some have the same access hole that CD-Rom's have. Using a paperclip, push through that hole until it bottoms out, your on the button. You have to use some force to press this since it is a manaul release lever your actuating. Good luck
MY DAUGHTER PUT A CD IN THE CD PAYER AND NOW MY CD PLAYER DOES NOT WORK.I HAVE A 2005 NISSAN ALTIMA.THE KIND OF RADIO IS A BOSE 6 CD CHANGER.I PRESS THE CD BUTTON AND IT SAYS PUSH EJECT.I PUSH EJECT AND IT SOUND LIKE IT'S TRYING TO EJECT BUT NOTHING COMES OUT.CAN YOU HLP ME
Then I unscrewed the bottom panel of the radio. Unscrew the brass screws holding in the cassette player portion of the radio. Now flip the cassette player over to see your tape, etc. When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound. I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
