Removed original module replace it with 512 module..it boots. iserted anther 512 module( matched pair) into slot 2 , refuses to book with boths slots occupied.. any suggestions ?
512MB (FT64MSD64V3F)
200 Pin Dimm - SDRAM - 2.5V - DDR - PC2700 (PC-333) - Non-ECC
is the correct type of RAM for your laptop.
Have you tried booting with all combinations.
512 in slot 1 --- Boots
move same dimm to slot 2 (on it's own) and try booting.
boot with 256mb in slot 1 and known to be good 512 in number 2
This laptop should allow up to 2GB RAM. So I don't belive it is an issue with the mother board not seeing the amout of RAM. I think it could either be flaky dimm or your slot 2 is damaged
have tried all of the above combinations...(every dimm works on it's own in slot 1) ....slot 2 damaged ? if you insert a dimm into slot 2 on its own an audible alarm sounds so it appears that slot 2 is addresed by the bios when it is booted.
