I noticed finals are mosfet they will take alot of punishment from a bad antenna system match "high SWRs If the meter is moving at all on keyup i would not suspect finals. Finals seldom degrade in power they just quit. The driver for the Final transistor another transistor can produce low transmit power with a failed Final.
You say it is in a Dumptruck lots of vibration and dust. It could be cold solder joints..cracks in solder and corrsion in cracks reducing voltage to components. Dust or dirt in trimmer pots which are varible resistors.
Open case on solder side (top of radio)and tighten phillips head screws dont over tighten these boards can be fragile. After opening that side you will understand the dust issue.
I suggest checking the easy stuff first.
1. check power leads
2. Swap mic.
3. check coax connections.
4. check coax for damage.
5. swap antenna they can have broken wires.
6. make sure the plastic insulator on top that antenna is inserted in is on top and coax side is contacting antenna mount for ground.
