Most common problem of this phone is the censor or the navigator due to water damage or dropping the phone in high place etc.
Check this procedure :
* Remove the back cover of the your phone.
* Remove the battery.
* you can see a screw with a metal shield in the middle part. Unscrew the screw using a T6 precision screw driver and remove the metal cover.
* you will see a flex cable connected on the socket and that would be the censor or navigator we're looking for.
* check and clean the socket or connector with a solution or lighter fluid together with a cotton.also clean the socket of the censor. then put it back and assemble it then try if it's working.
If it's not working, then needs a censor replacement.you can buy to any parts dealer or distributor nearest you. this is so easy to do so you don't have to bring it to a mobile phone technician for replacement just to save service fee and discount on parts too..
Good luck and thank you for visiting fixya.
Walmart have tent stakes that are reasonably priced and you can buy them individually which is really helpful. We lost just one of ours and I didn't want to replace the whole set. http://www.walmart.com/ip/COLEMAN-TENT-STAKES-10/13848624
