As per your information, there might be some problem with front panel microphone.
1(a). please check the internal cable for audio from motherboard to front panel. if possible change the internal cable.
1(b). If not avoid using the front panel and use the extention cables for extending from back points of speaker connection and microphone connection. just like usb extention cable you will find the audio/mike cable extentions can be found in local electronics shop. so that when ever you want you can connect speakers or headphone and also microphone.
2. For entering to BIOS, use either DEL key or F2 key when you power on the pc. In that you can see all the features. -
May be this helps to you.
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making VERY sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
