Take the cover off the inside unit and look for the drip pan under the evaporator coil. It should have either one drain in the middle of the pan or a series of smaller drains along the back of the pan. The drain(s) is probably clogged up and causing the pan to overflow into your home. Also check the drain line on the outside wall where the refrigerant lines come through the wall for a blockage.
