Had my LG for about a month. Sudeenly today it started to turn on and off - like it is recycling or something. Any idea this might be?
If it's only a month old, I don't suggest opening it up at all, as it will void your warranty.
Get it replaced under the warranty - that's what it's there for.
If however you live in some remote corner of the earth, and it will take you 8 months to get it to a location where you can get it replaced, here's what's likely going on, and how to fix it.
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
