Sony Bravia Remote Control 148016611 Logo
Posted on May 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have two Bravia TV's identical with 2 remotes both RM-YD028. Both remotes work with one TV, but one TV will not work with either remote. It appears the remote is okay.
Mando Mojica
Level 3:
  • Master 643 Answers
  • Posted on May 25, 2011
Mando Mojica
Master
Level 3:
Answers
643
Questions
0
Helped
299034
Points
1928
The infrared sensor on the tv is probably bad. Or make sure nothing is blocking the sensor on the tv. The remote is line of site. Hope this helps.
The problem with my KDL-37L5000 is I was using my direct tv remote while I had satellite. Now my tv remote won't work with it. The remote RM-YD028 is present for this tv. Help!!!
Hi Bruce, if you want to directly control your Sony KDL-37L5000 TV with your Sony RM-YD028 remote control, it should work without any problems, at most you will have to reconfigure it with the Sony TV code
I hope you can resolve your concern
Greetings Franco Dosil
Hola Bruce, si tu quieres controlar directamente a tu TV Sony KDL-37L5000 con tu control remoto Sony RM-YD028, deber?a funcionar sin ning?n problema, a lo sumo tendr?s que re configurarlo con el c?digo de TV Sony
Espero puedas resolver tu inquietud
Saludos Franco Dosil
https://www.sony.com/electronics/support/articles/00006831
https://www.sony.com/electronics/support/articles/00012375
Can I reset my KDL-37L5000 Sony bravia tv
Sony bravia remote not working, and tech says not remote need to replace the sensor in tv. Can a noon geek do that.
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
If the remote control is OK, the tech might be right. The infrared sensor inside the TV should be replaced.
1helpful
Does it have a sleep timer?
hello!
yes, it has the one! you need to go to the menu, setup portion of that. you'll see: clock set, timers, etc. That's where you will find it. A bit complicated, but possible. If your remote lacks "sleep" button, get the one with it.
good luck,
Alex.
3helpful
My RM-YD028 Sony BRAVIA Remote Control has stopped working, how do I reset?
Remove the batteries from the remote and wait 5 minutes or more. After waiting, insert the batteries again. The remote should now work. If it's still not working, the remote is probably defective. If that is the case, please contact Sony Customer Support, which will be able to assist you in getting a replacement issued.
I have a Sony Bravia TV, only a year old, had several power outages and suddenly RM-YD028 TV remote is not working at all. On the Dish network remote, the satellite controls are working, but not TV...
If neither the DISH Network remote or the TV remote is working for you most likely your remote sensor is going bad. If you'd like to try readdressing the remote follow the steps and procedures below. Codes: 500, 837, 125, 808, 798, 640, 796, 783, 795, 797, 865, 846, 842, 563, 501, 810, 841, 781, 807, 838, 690, 758, 843, 845, 591, 839, 806, 840, 844
To program the remote:
1.) Hold the clear "TV" mode button for four seconds or until all four buttons at the top of the remote are lit.
2.) Press one of the three digit codes listed above followed by pound (#)
3.) Check for functionality by trying the volume power and mute.
Be sure to press the "SAT" button to return to satellite mode if the code works.
Daniel Busa
DISH Network
Customer Service
MY Sony Bravia remote control pn# RM-YD028 has stopped working.
ebay is your friend.
Please dont forget to vote if you liked my answer
thanks
Sony model KDL-32L5000 does not respond to the commands of its remote control model RM-YD028. We have been using a Direct TV remote as well to control volume but its not reacting this remote either...
If the only thing not reacting is the audio, then the audio board or the main board has gone bad. Enter the model number and tv make on you tube to get more detailed info.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
