The problem with my KDL-37L5000 is I was using my direct tv remote while I had satellite. Now my tv remote won't work with it. The remote RM-YD028 is present for this tv. Help!!!
Posted by Bruce Smith on
Franco Dosil
    Top Expert:
  • Televison & ... Master
  • 10,535 Answers
Hi Bruce, if you want to directly control your Sony KDL-37L5000 TV with your Sony RM-YD028 remote control, it should work without any problems, at most you will have to reconfigure it with the Sony TV code
I hope you can resolve your concern
Greetings Franco Dosil
Hola Bruce, si tu quieres controlar directamente a tu TV Sony KDL-37L5000 con tu control remoto Sony RM-YD028, deber?a funcionar sin ning?n problema, a lo sumo tendr?s que re configurarlo con el c?digo de TV Sony
Espero puedas resolver tu inquietud
Saludos Franco Dosil
https://www.sony.com/electronics/support/articles/00006831
https://www.sony.com/electronics/support/articles/00012375
Posted on Sep 15, 2019
5 Related Answers
dinomb
dinomb
  • 16 Answers
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
Posted on May 11, 2008
Anonymous
SOURCE: TRYING TO PROGRAM MY NEW SONY RM-YD024 REMOTE
Try these
For Direct TV:
00099, 00247, 00392, 00566, 00639, 00749, 00819, 01076, 01108, 01109, 01142, 01377, 01392, 01414, 01442, 01443, 01444, 01609, 01639, 01640, 01749, 01856, 20739
For Panasonic Satellite receiver:
00247, 00701
You can also look here:
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMYD024
Posted on Dec 23, 2008
Anonymous
SOURCE: Have sony RM-AV3000 need code for direct tv Hr20-100s
how to program the remote control sony model RM-AV3000
Posted on Mar 16, 2009
Anonymous
SOURCE: Toshiba Regza 32LV67U remote control code CT-90275
my lcd screen toshiba is broken, what can make??
Posted on Aug 17, 2009
freetek
Steve Allison
  • 5569 Answers
SOURCE: Not Working RM-YD028
Be prepared for sticker shock:
Posted on Oct 04, 2010
What's the difference between sony rm-yd028 or rm-yd065?
To most Sony remote controls, P+ / P_ & Vol+ & Vol -- ; buttons will work, except for other buttons will work. The difference between the Sony remote controls you mentioned here too will differ to these function. http://electronicshelponline.blogspot.com/
Oct 19, 2014 | Televison & Video
Does it have a sleep timer?
hello!
yes, it has the one! you need to go to the menu, setup portion of that. you'll see: clock set, timers, etc. That's where you will find it. A bit complicated, but possible. If your remote lacks "sleep" button, get the one with it.
good luck,
Alex.
Dec 09, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have a Sony Bravia TV, only a year old, had several power outages and suddenly RM-YD028 TV remote is not working at all. On the Dish network remote, the satellite controls are working, but not TV...
If neither the DISH Network remote or the TV remote is working for you most likely your remote sensor is going bad. If you'd like to try readdressing the remote follow the steps and procedures below. Codes: 500, 837, 125, 808, 798, 640, 796, 783, 795, 797, 865, 846, 842, 563, 501, 810, 841, 781, 807, 838, 690, 758, 843, 845, 591, 839, 806, 840, 844
To program the remote:
1.) Hold the clear "TV" mode button for four seconds or until all four buttons at the top of the remote are lit.
2.) Press one of the three digit codes listed above followed by pound (#)
3.) Check for functionality by trying the volume power and mute.
Be sure to press the "SAT" button to return to satellite mode if the code works.
Daniel Busa
DISH Network
Customer Service
May 31, 2011 | Sony RMYD028 Remote Control
I have two Bravia TV's identical with 2 remotes both RM-YD028. Both remotes work with one TV, but one TV will not work with either remote. It appears the remote is okay.
The infrared sensor on the tv is probably bad. Or make sure nothing is blocking the sensor on the tv. The remote is line of site. Hope this helps.
May 25, 2011 | Sony Bravia Remote Control 148016611
Tv button on remote does not power on my tv neither does comcast remote
U try to power on the tv by pushing manual power button on the tv itself?Yes,tv still have no power than ur tv have power supply board problems,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.If it the remote problems call ur cable company for the cable remote replacement.Try website like Remotes.com to buy the tv original remote for the replacement.
Apr 13, 2011 | Sony KDL-37L5000 37 in. LCD TV
Remote doesn't work.
Please replace batteries in remote and check.
Try another Sony tv remote or Sony dvd player remote that also has power, volume and channel up/ down buttons for Sony tv.
If no remote works on this tv then it would be bad remote sensor located on front of tv, its small circuit board that will be replaced to solve the issue and local tv repair shop will help you if you are not familiar with electronics stuff repair.
Hope this will help.
Thanks.
Mar 19, 2011 | Sony KDL-37L5000 37 in. LCD TV
Sony model KDL-32L5000 does not respond to the commands of its remote control model RM-YD028. We have been using a Direct TV remote as well to control volume but its not reacting this remote either...
If the only thing not reacting is the audio, then the audio board or the main board has gone bad. Enter the model number and tv make on you tube to get more detailed info.
Dec 15, 2017 | Sony KDL32L5000 32 in. LCD HDTV
I purchased a brand new Sony Bravia KDL-32L5000 LCD digital color tv with a remote RM-YD028 which worked fine for about 1 year. Then, the remote completely stopped working. Double checked the...
From your description, I would suspect that the IR receiver inside the TV has failed. If the TV can be controlled from the panel buttions, that adds to that suspicion. Please note that it is possible that the receiver has poor solder connections and that this can be easily fixed. Even with replacing the receiver, the part would cost only around $10 or so. Check with local repair shops for a cost to repair this.
Dan
Aug 25, 2010 | Televison & Video
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Nov 19, 2008 | Sony RM-AAP001 Remote Control
Open Questions:
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
