Sorry to hear/read this.
First, try get a new charger and plug your Google nexus 7. Suspect a dead battery with no charge left on it.
Otherwise, confirm your charger isn't just lighting up whereas it isn't delivering any charge current to your device.
Next to try if your ac charger is confirmed good is to attempt replacing the battery; at the store, have them insert a compatible/similar battery and then try power on your device.
NOTE:
New batteries at the point of purchase have some charge on them; sufficient to power on your device.
Device not power on, DON'T PURCHASE NEW BATTERY. Obviously, you don't have a power/battery problem.
Device power on, then you either have a battery that has failed or that your device's charging port needs to be serviced or repaired.
yes, you should be able to use your 255w while driving...if its going to the garmin screen ( or the screen with the computer icon) when plugged in to the car charger, then the car charger is probably either bad or not compatible with your unit..if its the original charger, i would buy another one thats made for a garmin.
the only time you shouldn't be able to use your 255w, is when its hooked to your computer.
i fix these and many other
gps daily so when considering
my advice , please understand i do not google my solutions.
Its appealing simple; Probably you will be accepting sony handcam charger accepting a cable thats declared to fit into ur camcorder and again allegation the battery. For charging the EFORCE FH50 battery, you just allegation to admit that the of the aforementioned cable anon into the battery(DC-IN slot) and bung ur charger into the bank socket. It commonly takes 135 mins to absolutely allegation the battery. Once answerable the LED at tthe DC-IN aperture will about-face off. (During charging its yellow)
Hi bro, I'm from philippines too...if you can't find a compatible charger for your phone here u can purchase one online or through the internet, it is even cheaper if you'll purchase online.
