20 Most Recent Sony Cyber-Shot DSC-F707 Digital Camera Questions & Answers
After much money at repair shop for green viewfinder,
3 minutes ago I rapped my F-707 sharply on the
camera bottom, and green disappeared. Everything
else appears to be normal now.
Sony Cyber-Shot... | Answered on Apr 13, 2014
Always be sure the battery is charged and suited for your camera.
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
If you have a multi meter, you can check your battery. After charging the voltage should be higher (few tenths of a volt) than the voltage printed on the battery.
If the voltage is slightly lower, you know thee will be not enough left when the battery needs to deliver some power.
Sony Cyber-Shot... | Answered on Jan 29, 2014
Same problem for me. The flash won't pop-up anymore, even when I select the forced flash.
Sony Cyber-Shot... | Answered on Jan 20, 2013
I used Super Glue and my camer ia stil working.  However you need to be very careful taht no glue gets onto the lens itself as it cannot come off and will give your pictures a blurred effect
Sony Cyber-Shot... | Answered on May 10, 2012
Is the memory stick 128Mb or less?
Sony Cyber-Shot... | Answered on May 02, 2012
You can try using NIMh batteries instead of using of using the conventional. Most other cameras with similar problems have turned to function normally by using the above mentioned cameras.
Sony Cyber-Shot... | Answered on Dec 16, 2011
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sony Cyber-Shot... | Answered on Jun 20, 2011
hi sony f707 and f717 have very common flash fpc(flexible printed circuit) torn due to flash defuse unit up/down many time. it just need replacement. Thanks and best regard!
Sony Cyber-Shot... | Answered on May 25, 2011
There is no setting to change self timer, default time is 10 seconds. However you can reset camera to restore default settings by pressing reset button located under battery compartment, try it as it might correct self timer problem.
Thanks.
Sony Cyber-Shot... | Answered on Jan 05, 2011
I'm sorry that the internal flash does not pop open when required. Refer the URL to troublehoot the issue: The built-in flash does not function.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C95364&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=210198758&stateId=1 0 210210555
Sony Cyber-Shot... | Answered on Dec 23, 2010
The problem is that if you ever use the memory stick on other camera besides the Sony DSC-F707 or format the memory stick on a computer instead of using the camera's format feature, then you will experience the "Memory Stick Error C:13:01" problem.
Here's the solution that finally will solve your issue. Take any lead pencil. Take the eraser and rub it on the gold contacts on the memory stick as if you are erasing writing on paper.
Do this for about 30 seconds or more until you get all the gold contacts. Put the stick in the camera, switch to 'Setup', then turn the camera on. The 'C:13:01' error will automatically disappear. At this point, quickly format the memory stick using the camera's format feature.
CAUTION: NEVER FORMAT YOUR MEMORY STICK ON OTHER CAMERAS, USING A COMPUTER WITH A MEMORY STICK READER OR USING WINDOWS XP WITH A USB CABLE PLUGGED TO THE CAMERA. IT DOESN'T WORK. FORMAT YOUR MEMORY STICK USING THE CAMERA'S BUILT IN FUNCTION ONLY.
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Sony Cyber-Shot... | Answered on Dec 03, 2010
FLASH STOPPED WORKING
Sony Cyber-Shot... | Answered on Oct 18, 2010
The answer is yes as long as they are the same type memorystick.
Sony Cyber-Shot... | Answered on Sep 26, 2010
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sony Cyber-Shot... | Answered on Sep 17, 2010
This seems to be an issue with the CCD Image Sensor failure in the Camera. If you're able to view the previously captured images and display icons on the Camera, then the issue is with the CCD.
Try resetting the Camera to resolve the issue.
The RESET button is located inside the Battery / Memory Stick cover. To reset the camera, press the RESET button using a sharp-pointed object.
Please make sure that you turn ON the Camera before you reset it.
If the issue is not resolved, then remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue persists, service may be required.
Sony Cyber-Shot... | Answered on Jul 25, 2010
Hello :
Look for a tiny switch on the side of the SD card . This switch indicated [ Locked or Unlocked ] . You need to unlock it . If that didn't help , then you need to format the SD card before using it . If that didn't help also , then the problem is with your Camera and not with the SD card . there also must be a sensor in the [ reader on the camera ] which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card . but you could try blowing out any possible dirt and see if that fixes the problem .
fbf2fa3.jpg PLEASE DON'T FORGET TO RATE !
GOOD LUCK .
Sony Cyber-Shot... | Answered on Apr 08, 2010
Sony Cyber-Shot DSC-F707 Digital Camera Logo
70 questions posted
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
lcd screen sony dsc f707 green
  • Cameras
