Hi
Noise Coming from Inside
In case of a self-defrosting refrigerator, the source of noise is
generally from the inside of the refrigerator. Basically, a fan is used
in this type of refrigerator for proper air circulation through both the
compartments; the fridge and the freezer. The placement of fan depends
on the structure of your refrigerator and where the freezer compartment
is located.
If freezer section is on left side of your fridge, the fan is usually
located on the topmost part of the back wall. If the freezer is at the
bottom, the fan is on back wall in level with top edge of the freezer
section. In case the freezer compartment is at the top, the fan is on
the back wall, near the bottom or top or center of the freezer. So all
you need to do for checking whether the fan is faulty and the cause of
noise is to open the freezer and push in light/fan switches. If the
noise becomes louder, the fan motor is faulty. If lubrication and repair
of the motor doesn't help, you need to replace it.
If the source of noise is from inside the fridge or the bottom-front
side or the food compartment, it's usually caused due to a damaged
defrost timer. Just replace the defrost timer and check out.
Noise Coming from Bottom
If you can hear the noise coming from the bottom, check if the drain pan
is rattling due to improper placement. Place it properly. If required,
tape it in place to stop the noise. If this is not the cause, but you
hear noise coming from the bottom, most commonly the problem source is
actually at the back of the refrigerator.
Noise Coming from Backside
First of all, you need to open the back panel. Some refrigerators might
not have this panel or just have a net type panel. Once you open the
back panel, check the following to fix noisy refrigerator problems.
The problem may be caused due to a damaged noisy refrigerator
compressor. A compressor is a single part, without any other moving part
and is football sized. It is usually black in color and situated at the
bottom with some tubes or wires attached to it. If this compressor is
making noise, which will generally be loud enough, it needs to be
repaired by a professional. The compressor might also be needed to be
replaced.
