Hello, I have now had 2 engineer visits. The noise doesnt happen when they are here and then (of course) occurs shortly after they leave. The first chap moved a little pipe from vertical to horizontal and the 2nd engineer has tightened the back panel of the machine. Now on hold for some 40 min to ask someone to come out again. It also whistles and makes a sort of bubbling groaning noise. Either it's haunted or there is a fault! It is under a year old and specifically a 77684. Hopeful thanks for suggestions....Claudine
Think the door was left cracked open all day while we were at work, so it had to work to keep cold all day- and now it's making this horrible noise and not really cold as it should be. the noise is coming from the back, there are a few things that could be causing the problem. If the unit seems louder when the compressor starts, it's probably a normal sound. The compressor starts with a high pressure, but as the pressure balances, the noise should become normalized. The compressor is in a black case with no visible moving parts. It's located at the back of the refrigerator near the bottom and has wires and a bunch of tubes going to it. If it's humming, or making a steady noise, and your refrigerator is still not cooling properly, there could be a problem with one or more various components. If the compressor is making noise, there's probably no repairing it. You'll have to replace it. This is often a very costly job and needs to be done by someone with the necessary EPA certification to work on sealed systems.
SOURCE: Fridge freezer KIM 29473GB/01
Liners are not able to be replaced. Will need to buy a new unit if the liner is a problem.
SOURCE: GE ADORA DSS25KSRDSS FREEZER FAN NOISE
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
SOURCE: top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
- sorry that should read LOUD not lough!
