Radio Shack Pro-83 Scanner Logo
Posted on Aug 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PROGRAMING HOW DO I PROGRAM FREQUENCYS INTO MY SCANNER AN PUT 10 IN EACH BANK
Greg Cann
Level 3:
President:
  • Master 1,114 Answers
  • Posted on Aug 15, 2008
Greg Cann
Master
Level 3:
President:
Answers
1114
Questions
Helped
711087
Points
3906
Hi - You can download the manual from the link underlined in blue below:
Pro-83
See pages 24, 25:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Error meassage keeps comming on when trying to program frequencys
that is because you are trying to program frequencies into the scanner with hitting your program button...hit your program button.. its your prg..button when you hit your program button then try putting your freq in...
Pro 84 scanner how to search for frequencys between 144.00 and 148.000
You can download a copy of the user's manual here if you need it. It doesn't look like you can set your own scan range, but you can have the scanner search by pre-defined service. Here's what the manual says about searching:
service search
You can search for weather, ham, marine, aircraft, or
police (fire/emergency) transmissions without
knowing the specific frequencies used in your area.
The scanner is preprogrammed with all the
frequencies allocated to these services. To use this
feature, press FUNC + SVC. SRCH appears and the
scanner searches starting with the weather service
bank. To select a different service bank, repeatedly
press FUNC + SVC. Service mode appears on the
display.
When the scanner stops on a transmission, quickly
press HOLD to stop searching and listen to the
transmission. HOLD appears. In this mode, you can
press FUNC + ^ or FUNC + v to step through
the frequencies.
To release the hold and continue searching, press
HOLD. Or, if you did not press HOLD, simply press
FUNC + ^ or FUNC + v to continue searching.
It goes on to explain how to store frequencies as you find them while searching.
3helpful
How to program
There are several ways to program your scanner, so it's best that you refer to the owner's manual for detailed instructions. You can download/view/print the manual at:
http://uniden.com/pdf/BC350Aom.pdf
Entering radio code
i have a pro 94 dual trunk scanner,how do you program,and where do you get police frequencys for vancouver,wa
2answers
Can't get Hopkinville police radio on my scanner
I know that most frequencys did change, I had the same problem when all the police went to digital, I had to put in new frequencys.
How to program my uniden bcd 396T?
go to bc tool join, radio reference group one you have both you can import frequencys from radio reference group to bc tool program then upload file to scanner
Missing numbers
Press 'scan', then press 2, 6, 9 & 10.
3helpful
3answers
How do I Program my Uniden Bearcat BC60XLT
i am having trouble programing frequencies into my scanner i need help!!!!!!!!!!!!!!!!!!!
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
