Troubleshooting & Support for
60,451 people viewed this product
Hi, To unlock all your channels do the following: Press Mon/Hold, press 1, now press L/O, channel 1 i...
Turn the scanner on. Press "0" Press "1" Press "ENT" Now press any key Now press any key aga...
Hi, I can help. If you have some bands locked out (not all bands can be locked out. By default 1 w...
Hi, I can help. You probably have all frequencies in that bank locked out and all other banks loc...
hello firstly select the mode and bank number ,press and hold L/o button this will unlock all cha...
To RESET the scanner and delete ALL programmed frequencies: - Power the scanner OFF - Press and hold the...
There isn't a Firmware upgrade for this scanner and I also do not think it is capable of Decoding the...
Lets see if I can help you.....Turn on the unit, Press PGM, press TRUNK, select group using up or dow...
Turn it on, and when "Welcome" appears, press zero, then press one. It will display a message ind...
Sorry, but it can't be done, for at least two reasons. Cellular bands are out of the tuning range of ...
The linked article below indicates that the PRO-95 and other non-digital Radio Shack scanners are not...
What is the frequency?You can get them for your state at RadioFreq.com ....hope this helps...
Your scanner has somehow gotten out of alignment, and there's no way to fix it with just a scr...
no there are no adjustments, you need to check to make sure tha tthe pro-95 you have is compatible wit...
Have a tip for Radio Shack Pro-95 Handheld Scanner?
I have a pro-95 scanner and I also have the usb connector but I'm not sure how to use it....
JUST GOT THIS HAVE NO CLUE HOW TO PROGRAM THIS INTO IT. 16688 413 A 7-RedPD-1 Police...
When the device receives surrender, gave the signal indicates an incoming call
i can only hear the dispatcher on my pro 95 no police unit replies at all
it is programmed and you can visually see it transmitting but you cannot hear the people talking
Need pin out and the signal level converter I need to use. Hoping someone can post this so I can...
| Key Features | |||
| Full Product Name | Radio Shack Pro-95 Handheld Scanner | ||
| Type | Handheld | ||
| Number of Channels | 1000 Channels | ||
| Number of Bands | 9 Bands | ||
| Modes | AM, FM | ||
| Band Coverage | |||
| Band Coverage | 25000 KHz - 1300 MHz | ||
| Continuous Coverage | Non Continuous Coverage | ||
| Dimensions | |||
| Depth | 1.75 in. | ||
| Height | 6.19 in. | ||
| Width | 2.44 in. | ||
| Weight | 53 lb. | ||
| Warranty | |||
| Warranty | 1 Year | ||
