Try to speed up your computer by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
If problem persists, do the following.
Backup your data before masterreset, as it would erase all installed data. Press Ctrl + Del keys simultaneously. Click on restore > Confirm > Finish.Click Yes to allow computer to reset. Now click on Next and then systemrestore. After another restart, you have reset your computer factory settings.
To do a factory resore and remove all data look at the boot up menue it will tell you to push a key generally F10 or F8 to start factory restore.
However you can fix your slow pc with out doing that by running the command "msconfig".
Go to "run" from the start menu
click run and type msconfig in it
next go to that startup tab and disable all.
next look for sound and video drivers (nvidia, ati)that may need to be on. and turn them on
(Things like adobe reader and ms office can be safely turned off and will still run fine)
now reboot you should have a mutch faster pc.
Don't forget to rate.
