Hi
Please check your iphone power walt, bay be its not support that big speaker's
Did you connect it to the AUX input? Did you use an RCA dongle for it? If it is connected to the headphone jack, you will get no sound. Also, you need to make sure your stereo is on the correct input for it...you will probably have a CD input, a DVD/Blu Ray input, TV input, etc. Sometimes I forget to switch mine and have the same problem. Also, if "mute" is pushed on your Ipod, no sound will come from your stereo. I've had 5 different IOS devices and have never had any problems connecting to the stereo system, so chances are you have a fixable problem.
Hope this helps.
The connection you made is wrong. You have to connect the phones form the IPod to any available line in of your amplifier - audio system using a cable like this
This cable is common known as 3.5mm male jack to 2 male RCA.
In case you'd like a link to buy on line this cable or if a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Automatically setting up for surround
sound (Auto MCACC)
The Auto MCACC Setup measures the acoustic characteristics of your listening area, taking into account
ambient noise, speaker size and distance, and tests for both channel delay and channel level. After you have set
up the microphone provided with your system, the receiver uses the information from a series of test tones
to optimize the speaker settings and equalization for your particular room.
Make sure you do this before moving on to Playing a source on page 11.
Important
• Make sure the microphone and speakers are not moved during the Auto MCACC Setup.
• Using the Auto MCACC Setup will overwrite any existing settings for the MCACC preset you select.
• Before using the Auto MCACC Setup, the headphones should be disconnected and the iPod
USB, XM or SIRIUS Radio function should not be selected as an input source.
1 Switch on the receiver and your TV.
2 Connect the microphone to the MCACC SETUP MIC
jack on the front panel.
Place the microphone so that it's about ear level at your normal listening position (use a tripod if possible). Make
sure there are no obstacles between the speakers and the microphone.
The Auto MCACC display appears once the microphone is connected.1
Note
1 • You can't use the System Setup menu in either the main or sub zone when the iPod USB, XM or SIRIUS Radio input source is selected. When you set ZONE 2 to ON (page 61), you can't use the System Setup menu.
• If you cancel the Auto MCACC Setup, or leave an error message
etc.
It's all in the manual.
Some background on the process...
http://www.pioneer.eu/eur/products/42/98/tech/AVAmplifierReceiver/AF_MCACC.html
