Mixer XLR main output to AVR Receiver as RCA not sound on main speakers
I purchase a Mixer Pyle PMX466 that has XLR main output, so I connect a wireless microphones to the mixer (XLR cables) but when I set the source of the receiver were i put the RCA (CD source) I'm not hear any sound. I talk and see the power LED bar rising like is getting the sound but seems like is not sending out to the receiver.
Novelist:
Expert
Re:
It sounds like the issue might be with the routing of the signal from the wireless microphone to the main output on the mixer. Make sure the wireless microphone is plugged into the correct input channel on the mixer and that the channel is properly selected and turned up on the mixer.
Also, make sure that the main output on the mixer is selected as the output source and that the level is turned up to an appropriate level. It's possible that the level might be too low or the wrong output might be selected.
If you're still not getting any sound, try plugging in a different audio source (such as a phone or MP3 player) into the mixer's input and see if you can hear any sound through the main output. If you can hear sound from another source, then the issue might be with the wireless microphone or its connection to the mixer.
I had a brief look at the spec and it says the speaker outputs are banana sockets/plugs.
Once the four speakers are connected, or two with the fader control adjusted, it should produce good sound and if it does the next stage will be to connect the subwoofer with RCA plugs into the dedicated outputs.
Your Genelec 1037C monitors are professional design with balanced inputs. Balanced inputs expect a low impedance signal with pin 1 earth, pin 2 hot and pin 3 cold. Because the Denon amplifier supplies a pre out for the front speakers (the first pair in the set of pre outs) at 1.2 volts and high impedance, you will need to convert the signal close to the amplifier with a stereo active DI box. Plug the pre out directly into the input of the DI with a SHORT lead and then plug two standard balanced microphone type cables ( XLR to XLR) into each of your active monitors. You cannot make a cable that is RCA to XLR by shorting pin 3 to earth to do this job properly. The inputs on your Genelecs expect a signal in the range -6dBU to +6dBU for rated output. A suitable DI box would be for example a Klark Teknik DN200. Hope that helps.
Cheers, Don.
This option requires that you add a separate power amplifier.
1) Connect the pre-out main left and right to the EQ901 inputs 1 and 2, and the EQ901 outputs 1 and 2 to the power amplifier inputs left and right
2) Connect your 901 speaker to the power amplifier outputs
3) The equalized signal will now play through the front left and right speaker outputs in the stereo and home theater modes.
You need to connect the speakers using an XLR cable into the Main output jack on the back of the mixer. If they are powered speakers you will need to connect them into a power source and turn them on AFTER connecting them. Once powered on you can control the signal going to the mixer with the Main Mix fader.
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Your power amp should be connected to MAIN OUT left and right. NOT the MAIN "in".
The CD is connected correctely as you described. Make sure the CD has a line level output to match the input expected by the mixer.
Note:Walkman style CD players require a special cable to go between 1/8 inch stereo to dual RCA plugs.
You have to advance the MAIN fader.
You should be using TRS interconnect cables from the mixer to your amps OR using XLR cables.
You CANNOT have a stereo set of RCA jacks "wyed" into a single XLR mono input.
The RCA output drivers will "fight" each other. Some things will appear to work, but give poor performance.
You could make a rudimentary passive mixer by putting a series resistor say 1K ohms from each of the RCA's to a common UNBALANCED input of a subwoofer.
The XLR is balanced so that would not really work unless you also have an unbalanced input on the subwoofer.
The right way to do this is to get a cheap two input mixer that has EQ with it and mix your two mains before sending to the subwoofer. You want a little mixer that also has balanced outputs (XLR or TRS) to send to the subwoofer.
UNLESS the subwoofer has EQ in it, you really need to have an EQ in the little mixer so that you don't send high's to the subwoofer... They don't like highs and the sound will suffer.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
ok i have the same reciver do you use hdmi to go to your tv or componet what ever you use there will be an audio out for rca on the cable box if you dont use a cable box keep reading but use hdmi to tcv then the rca audio out to the denon avr 900 obviously out it in the vdp/tv unput. and if you dont use a cable box your tv shoiuld have an audio output in the back of it for rca connect rca to audio output then other end to the denon avr 900s vdp/tv input
I am not sure about that brand but on my Roland Speakers, the TRS jack lives inside the XLR. I first missed it. Take an XLR and try to connect. I can't imagine that they would not have XLR especially for studio monitors.
Also are your speakers passive or active, that is something that I would seriously at. No amplitude, low signal, no active.
