SOURCE: Hi my Fisher & Paykel Paprika stove (Model
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
SOURCE: hello we have a fisher and paykel classic stove
Isolate power from device, remove screws to free back panel.
Loosen strainer for oven liner on left and right sides and remove clip to allow oven liner to slip forward.
Remove screw on front central upper clip.
From front, move oven liner forward a few millimetres to release gasket. Here you see the strainer at the rear has moved forwards a few millimeters.
Remove the old perished seal.
The new seal/gasket part number 573263 is installed. Reverse dismantling procedure to complete reassembly.
