New dryer making slight squeaking noise. Will this stop, only ran 2 x so far. I bought this off a guys dad at work who had it in his garage for 6 months but never hooked it up. When I picked it up I layed it on its side carfully,
Hi, You probably will need the following parts to fix the squeal; 6-3705180 Idler arm $6.78 6-3700340 bearing $16.04 [2] 6-3129480 Drum roller shaft $5.53 [2] 12001541 rollers $22.04 33002535 belt $23.80 MAKE SURE DRYER IS UNPLUGGED BEFORE WORKING ON IT Remove two screws at front bottom, pull front out toward you and remove wires from door switch and remove. Remove front bulkhead and drum. Check all of these parts I listed and replace as needed. Hope this helps
On a GE dryer the part that squeaks most is a WE3X75. Centerpost drum bearing. It is a simple repair but you must get into the machine.On a frigidaire model The plastic bearing that mounts in the rear sorta like a GE model. No other dryers that I can recall have the squeaks. The newer GE dryers are made very simular to the old reliable frigidaire models so you ought to hit it out the ball park with these 2 links.
