20 Most Recent Frigidaire FDE336RE Dryer Questions & Answers
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Frigidaire... | Answered on Mar 24, 2017
Try running the dryer with out the vent hose connected see if the problem persists. This will eliminate the ventilation system of your home from the equation. Then if problem persists must gointo the dryer.
Frigidaire... | Answered on Jul 19, 2014
most likely cause is a broken belt.next time send the model number,i can look up your model and give part numbers.
Frigidaire... | Answered on Oct 08, 2013
2 questions are there more then 3 elbows in your vent run
and is any of it flexible pipe?
Humidity will infiltrate but should be infiltrating that much. One thing they make for dryer vents is a flap that opens one way to let air out, while dryer is running and closes when dryer is off. I don't think its humidity causing your issue. When you say the vent is straight does it run horizontal (even with the floor) or does elbow down and then run straight/horizontal?
Also about how long is the pipe run?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Frigidaire... | Answered on Aug 24, 2013
Hi. The wire burned off because the timer went south. replacing the timer should solve that problem.
If you go to http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dryer-Parts/Model-FDE336RES1/1428/0151200/Y2704412/00005?blt=06&prst=&shdMod=
you will see the thermal block on the motor.
Joe
Frigidaire... | Answered on Sep 15, 2012
Dryers Logo
100 questions posted
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
will burn marks clothes sometimes
  • Dryers
