You sure it isn't the condensate from the Air conditioner?
You should have antifreeze in the radiator,not just water.
If this is clear water,it's probably condensate and no problem.
BTW,if you weakened your antifreeze solution by adding water to it,you might want to check if the freeze point is still around 30-40 below zero Fahrenheit. don-ohio (:^)
Your fan & pulley are bolted to the waterpump. You need to remove plastic fan schrod, then fan, pulley, belt then you will see waterpump bolted to front of engine. Stop by any good parts store, have them look up waterpump and show you what it looks like. Then you'll know what to look for.
Water is getting on your distributer cap..It is located directly under the water pump and getting wet..It comes as a kit (distributer cap,rotary button) and is around $120-$160.. Water pump has to come off to get to it and need to replace it as well when its off or you will just get the new one wet.
i think your water pump is done for. replace pump and the belt and you should be good to go. that lower pipe always rotts out on these vans. might want to replace the coolant bypass hose on top while your at it. it tends to brake around the same time as the lower pipe
hey if you changed all of that, i think the problem is the waterpump, my car had that problem and finally i found that that was leaking from the waterpump, but very carefull if you change it because if you move the timing belt the wont start. a mechanic charges around $225.00 to fix the water pump, the water pump is around 42.00 to 50.00 don't pay more than that.
