Samson R21S Microphone Logo
Posted on Apr 26, 2011
Do i need a driver for mic r21s to work on my compuer for karaoke?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
3036
Points
8
No, but you do need one thing. You have two options. Option one is a Mixer with USB output or USB Interface. Option two is to buy a USB Audio Interface. Personally, I'd go with option one because you can control every aspect of the mic and the music or instrument. The USB Interface does need a driver but it is included. The R21S Mic is an XLR Dynamic Mic.
How do I connect my wireless mic to my karaoke
Simply connect the mic-level output from your wireless mic receiver to the mic input on the karaoke system.
Can i use karaoke mic in harman avr 245 ?
No. The 245 doesn't have a microphone input. Besides, the speakers for a home surround sound system are a bit too delicate for the distortion levels generated by karaoke.
Here's a $300 speaker (yes, $300 for a single speaker) wrecked from teens doing karaoke. They then bust it more messing around trying to push the tweeter cone together so the crack wouldn't be so noticeable
If you still want to go ahead with the idea then you'll need some other bits of gear. For simplicity sake I'd recommend a karaoke CD+G player. It will have mic inputs, vocal echo, and take care of putting the works up on screen.
The alternative is a mixer with effects (echo, reverb) - Cheap is Behringer Xenyx 1202FX
and a source device for music and graphics. This could be your PC, but you'll then need to go trawling for karaoke files and you'll need some software to play them and do the words. Sax & Dotty is pretty good software.
The PC sound needs to be connected to the mixer in a stereo channel. The mic goes in mono on a mic channel. The output of the mixer goes to the AVR on an AUX input.
Behringer XENYX 1202FX
I just today bought a Samson R21S microphone, and I plugged it into my laptop via the laptops microphone jack, and immediately had problems. It cuts off my voice in mid sentence, it wont get half of my...
Not really the mic's fault - just incompatible.
Your Samson mic is a "dynamic" type and the laptop is expecting a "condensor" type.
You could put the mic through a preamp first but easier to exchange for a more suitable type.
Hope this helps.
http://stores.ebay.co.uk/methleykev
http://www.technicsdjuk.com/
I use a laptop,an external hardrive,and a mixer amp what is the best way to record some one singing on my karaoke to be able to burn it to disc for them to keep?Do you have any karaoke experts.....
I would suggest you to use a headset (without mic) and play the karaoke for them so that they can listen the music through the headphone while they sing. Connect the mic on the mic plug on your computer and record the songs they are singing with rhythm of the karaoke using an audio editor like Audacity or Adobe Audition and similar softwares. Suppose if you play the karaoke on your speaker, then the music will be heard from the mic and it'll be mixed up with the songs he/she is singing. For best result, Record the sound/songs and save it as different file and mixdown the karaoke file with it later. Otherwise, you'll not be able to get good songs. Please let me know if you need further help.
Good luck.
Thanks for using FixYa.
5helpful
Karaoke not working
Hi, got this info from philips customer service. Was desperately trying to get the karaoke function to work for 2 weeks! Plug in your microphone. Press "KARAOKE" button until you see "MIC OFF" text, and immediately press RIGHT button. It will now shows "MIC ON"! "ECHO", "KEY" options will now shows up when pressing "KARAOKE" button repeatedly. However, microphone sound will not be available on digital output, you'll have to use the audio RCA. Happy singing!
1helpful
Can not record with mic
For using the mic in karaoke you should mute the mic playback in windows mixer
2answers
Doesn't pick-up sound
First I'd check the cable and make sure it's alright. Try another cable you know is good. If it still has low output unfortunately, it's probably the capsule.If the mic is new I'd send it in for warranty repair if not contact samson @ their website for repair info.
5helpful
I CONNECT THE MIC TO MY LAPTOP BUT IT DOESN'T SOUND...HELP
mic connected to laptop but not working,please help me
What do you hook the microphone up on a stereo in order for it to work? My son says it is the AUX setting?
phones stands for headphone you can use aux input with help of(mic to line converter)from radio shack near you.-insert the converter in aux and insert the mic in converter.
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
