No. The 245 doesn't have a microphone input. Besides, the speakers for a home surround sound system are a bit too delicate for the distortion levels generated by karaoke.
Here's a $300 speaker (yes, $300 for a single speaker) wrecked from teens doing karaoke. They then bust it more messing around trying to push the tweeter cone together so the crack wouldn't be so noticeable
If you still want to go ahead with the idea then you'll need some other bits of gear. For simplicity sake I'd recommend a karaoke CD+G player. It will have mic inputs, vocal echo, and take care of putting the works up on screen.
The alternative is a mixer with effects (echo, reverb) - Cheap is Behringer Xenyx 1202FX
and a source device for music and graphics. This could be your PC, but you'll then need to go trawling for karaoke files and you'll need some software to play them and do the words. Sax & Dotty is pretty good software.
The PC sound needs to be connected to the mixer in a stereo channel. The mic goes in mono on a mic channel. The output of the mixer goes to the AVR on an AUX input.
Behringer XENYX 1202FX
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Testimonial: "cheers, have a good year."
SOURCE: No sound is coming out
Hi, Look at you speaker connections there is a short in 1 of them. That is why the protecion mode is on.
SOURCE: how do i reset an harman kardon avr-310
There is no reset for it, If it doesn,t stay on something is wrong with it,End it has to be taken in for repair,
1) Not with this unit. WHY bother? Sending identical program to two drivers over separate wires is the same as sending it over one pair.
2) No. Insertion of a microphone tells the unit you're doing setup. The microphone picks it up and sends it to a microprocessor for evaluation. The sound from the mic never finds its way out to a speaker. THAT would be a feedback loop and the tweeters wouldn't like it. (sizzle sizzle)
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-435-Receivers-manual/id/386bh037/t/2/
