20 Most Recent Creative Labs Sound Blaster Live! 24-bit External External Sound System Questions & Answers
windows xp cannot be installed on a system with pre loaded vista . because the boot loader of xp is older than vista as it cannot create boot loader . the order of installing operating systems is from LOWER 2 HIGHER ie XP to VISTA . first of all u nedd to format drive containing vista and then try installing xp
Creative Labs... | Answered on Sep 23, 2012
Try that link
Driver for :
OS: Windows XP,Windows NT SP3,Windows NT SP1,Windows 3.11,Windows 2000 SP3,Windows 2000 SP4,Windows 95,Windows NT SP2,Windows ME,DOS,Windows 98 SE,Windows NT,Windows 98,Windows 2000 SP1
Good luck
im not sure what you are referring to
click start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of the playback list also
right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality
Creative Labs... | Answered on Nov 04, 2011
could be a compatability issue or you might/will need to download the specific sofware
http://support.creative.com/Products/ProductDetails.aspx?catID=1&subCatID=206&prodID=10702&prodName=Live! 24-bit External&subCatName=Live!&CatName=Sound+Blaster&VARSET=prodfaq:PRODFAQ_10702,VARSET=CategoryID:1
hope this helps
Creative Labs... | Answered on Aug 18, 2011
hi i have now offic7 and when i instsll my creative sound card no.580490 throw my oregnal cd. some part of program did'nt work like amixer etc.and alaway's i got this not on my computer . thes deveic not deteceted ?\r\npleas help me
Creative Labs... | Answered on Aug 10, 2010
Is it just a replacement of a defective one? If it is, then, you still have the same operating system in it. Put your PC on, and left click, Setting, Control Panel, Systems, Hardware, and finally the Device Manager. You will now see the installed devices/hardware in
your PC. Right click over the sound, audio devices,
and view the status and property of this item. You
will be prompted on what to do next. If you don't get
results, your option is to reinstall the software driver.
If you have the CD for sound/audio software driver,
insert the disc and install the driver. If this is not
available, you can connect to the internet Just type at the search engine blank (Free download for sound/audio software driver) and click over it. Then, follow the instruction for you to get the free download.
the sound/audio software driver download
Creative Labs... | Answered on Nov 22, 2009
Creative lists this driver : http://support.creative.com/Downloads/welcome.aspx
If that dosen't work you could try the auto update here: http://support.creative.com/downloads/SoftwareAutoUpdate.aspx?AID=5902012&PID=2777698
Good luck
Creative Labs... | Answered on Oct 25, 2009
http://support.creative.com/Products/ProductDetails.aspx?catID=1&subCatID=206&prodID=10702&prodName=Live! 24-bit External&subCatName=Live!&CatName=Sound+Blaster- this is the best place 2 get software for that device, as it is the manufacturers website. i have several creative sound devices-and i get the drivers and software here. good luck!
Creative Labs... | Answered on Oct 22, 2009
For using the mic in karaoke you should mute the mic playback in windows mixer
Creative Labs... | Answered on Aug 30, 2009
If it were me, I would find out if 'ALL' of the drivers are available for XP. If they are, I would then downgrade to XP. I would also let Creative know about the performance problem. They may be able to fix it.
Creative Labs... | Answered on Jul 23, 2009
Remove the card and boot system. Shut down the system and reinstall the card. Your operating system should see it. If it does not then post again and I will help more.
Creative Labs... | Answered on Jun 08, 2009
Which windows version? Model number of you sound card?
Creative Labs... | Answered on Feb 27, 2009
This delay you are experiencing is called latency. All equipment or signal processing unit introduces some latency even if extremely low.
Computer tends to be a lot worse than outboard gear.
Look for Asio4All, this little driver will help you improve your audio input latency. And remember, the smaller the buffer size the lower latency you get.
Creative Labs... | Answered on Jan 25, 2009
yes it will :) if it has 6 female ports (the normal 3 + 3 extra) it will work just fine :)
Creative Labs... | Answered on Jan 19, 2009
use auto soft to solve this
Creative Labs... | Answered on Jan 10, 2009
Creative Labs Sound Blaster Live! 24-bit External External Sound System Logo
26 questions posted
Top Creative Labs Computers & Internet Experts
micky dee
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Creative Labs Computers & Internet
Most Popular Question
much creative labs usb sound blaster
  • Computers & Internet
