Hi there
There are a few of possibilities
Switch off and unplug before trying these.
1. You may not have got all the dust out of the condenser, sometimes you need to shine a torch through from the back and see if all the fins are clean, if not then a soft brush can be used with the vacuum cleaner to remove the rest of the dust.
2. There is a small temperature sensor either just behind the condenser or sometimes pushed in between the fins, this may have dust on it or it may be faulty. If it's faulty and you are competent with electrics it is fairly easy to change.
3. Is there a fan at the back of the condenser, and if so does it work. Again if it is not working its easy to change if you are competent.
However if you are not happy with electrics then you will need your local reputable service guy
Regards
Gordon
Testimonial: "Good advice"
