Home | Jackson | 24 in. JPX-300H Built-in Dishwasher | Acting strange
Jackson 24 in. JPX-300H Built-in Dishwasher
Problem for Jackson 24 in. JPX-300H Built-in Dishwasher
Acting strange
By dewcool on Aug 07, 2008
This unit runs fine for one time, then next it wont turn off, or it starts to leak all over, or it switchs to manual all by itself. I suspect a ele. part, like a motherboard if it has one
Solution #1
posted on Aug 19, 2008
Not Rated)
kermit854
Rank: Wiz
Rating: 87%, 20 votes
:o) The JPX300H doesn't have a "motherboard", but maybe a timing module. Either way, even if the machine only runs one cycle, it suggests the timing board is working correctly. You have multiple problems. For starters, the leak is probably a loose hose clamp, most are located on the unside of the machine. The most difficult are the drain lines which are to the rear.
The auto/manual switch is pretty straight-forward, but it is a two-part assy; the button, and the switch itself. Check switch for continuity.
Was this helpful?
Yes
No
Solution #2
posted on Aug 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
sorry, thought it was on there, model number jpx-300h
Solution #3
posted on Aug 07, 2008
Not Rated)
Master_Tech
Rank: Guru
Rating: 88%, 761 votes
what model (44??) you need to check the switches on the floats some fill with water but need the model to help you more
Was this helpful?
Yes
No
Popular Solutions for Jackson 24 in. JPX-300H
Questions and Unsolved Problems for Jackson 24 in. JPX-300H
Do you recommend Jackson 24 in. JPX-300H Built-in Dishwasher?
Answer
Answer
Dear Sir/Madam, I turn off unit at main switch, turn on again. Function switch still on R. Left red... (More)
Answer
water leak from door
Answer
It seems to run ok, but about 30 minutes into the cleaning process, we notice a burning smell that... (More)
Answer
how can i wire a jackson dish washer jpx 300h with out the relay useing a contactor
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jackson 24 in. JPX-300H...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
