Possibly a tstat issue. Run system until satisfied, once satisfied indoor fan shuts down compressor still runs remove tstat face plate and see if compressor shuts down. Another issue could be a sticking contactor for compressor. With a meter you could check at the contactor to see if you lose your 24volts for cooling but contactor remains pulled in.
Option 1: Easy One
Press and hold the power button between 5 to 7 seconds
This will turn off the laptop
wait for 20 sec after shutting down
Start laptop again
Laptop is ready to use.
Option 2: Moderate one
Remove the power cord from laptop
take the battery out
put the battery back
start your computer
Option 3: Difficult one
At this point I am not sure which Windows are you using and how do you usually log-in to the system.
I am guessing you got a new laptop, with Windows 7 installed.
The computer might asking you to press Clt + Alt+ Del to unlock the computer.
You can also see there is small button on screen which says "Switch User"
click on "Switch User" button
It will then ask your user name and password
Use your username and password the one you usually use to log-in to the system.
once you are logged in
restart the computer
it might ask you "other users are log-in do you wana continue"
press enter
the computer will restart and now you can use it as normal as before.
I experienced the same issue, it really happens during site maintenance. What you can do is to log out, clear cookies and cache, close the browser then try to log in again after a few minutes.
Sony are either doing a maintenence update or trying to fix the latest update bug that is preventing people from logging on. It will be fixed so give it some time and try again later.
personally i would call a tv repairman out to fix the set.you can get alot of different opinions on here about what it may or may not be but the best thing to do is call a repaiman and let them fix it
save your self the trouble if you have a flat screen TV you can connect to it NOW! if you need a second monitor you can go to a goodwill and buy a monitor under $40.00 I think is a good choice.
