Cars & Trucks Logo
Posted on Apr 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine vibration - Corolla Toyota Cars & Trucks
Level 3:
  • Toyota Master 17,130 Answers
  • Posted on Apr 06, 2011
Toyota Master
Level 3:
Answers
17130
Questions
0
Helped
3635798
Points
52372
Poor tuning of the engine can result in higher engine vibration. So the fuel and ignition timing MUST be trimmed to allow the engine to tick with ease. if this wont happen the health of the engine is under question and must be checked.
So check the fuel quality, filter and calibration- right fuel mixture of air/fuel.
Next the ignition timing to coincide with the correct timing mark and set using a strobe.
If this wont correct the valve settings, compression and timing must be rechecked.
Testimonial: "adviced the mechanic. working on it"
What causes a 89 dodge d50 newly rebuilt 2.6 engine to shudder and shake when turned off?
Vibration and shudder in a newly rebuilt engine can be caused by improper assembly, mass imbalance, camshaft misalignment, improperly adjusted exhaust pipes, or improperly adjusted carburetors or injectors. It is recommended that the engine be inspected by a professional mechanic to determine the exact cause of the problem and to correct it.
The causes are:
Improper mounting: If the engine mounting bolts are not tightened properly or are damaged, it can cause vibration. Similarly, an improperly installed motor mount can also cause vibration.
Ground imbalance: If the motor parts are not balanced properly, it can cause vibration when the motor is running.
Camshaft misalignment: Incorrect alignment of the camshaft can cause vibration when the valves and pistons collide.
Improperly adjusted exhaust pipes: Improperly installed exhaust pipes can touch other engine components and cause vibration.
Improperly adjusted carburetors or injectors: If the carburetors or injectors are not adjusted properly, it can cause vibration in the engine.
2kd hilux weak engine with mass smoke
The symptoms you're describing with your 2KD Hilux engine (weak engine with mass smoke, vibrations on rev, and less power) could be caused by several different issues. Here are a few possibilities:
  1. Excessive engine oil consumption: If the engine is consuming too much oil, it could be burning the oil and creating a lot of smoke. This could be due to worn engine components such as pistons, rings or valve seals.
  2. Clogged air filter: A clogged air filter can restrict the airflow to the engine, causing it to run poorly and produce more smoke.
  3. Timing issues: If the timing is off on the engine, it can cause poor performance, vibrations and smoke.
  4. Fuel injection system issues: A malfunctioning fuel injection system can cause poor engine performance, vibrations and smoke.
  5. Turbocharger problems: A malfunctioning turbocharger can also cause vibrations, smoke and less power.
Engine vibration
This is common on Hondas. If you want the vibration to go away you can adjust the idle to be higher. That's a fairly common fix. There's not really anything wrong though as long as it's not missing. Every engine has a speed it likes to vibrate at depending on how it was designed/built.
1998 Daewoo Leganza engine vibration
what about a crank pulley,or any other pulley bear a bend damage and on rotation cause the vibration?
What cause engine vibrations
Worn engine mounts that have gotten heat hardened from the engine heat will cause vibration at idle in drive.
2answers
2003 Jetta TDI vibrates above 35 speed
With 180k I would change the engine mounts. They are about the only thing that would dampen engine vibration and noise (assuming that the engine is running ok). There is likely one or all weak or broken. Normally when you have a vibration at speed then it is going to be driveline or wheel balance.
1helpful
3answers
Severe vibration
Replace balancer. You don't notice them until you rev it up.
3helpful
1998 honda crv vibrates when starting out
Increased vibration from a vehicle indicates worn out engine supports. This vibration often disappears when revving the engine high, but is very noticeable at low revs.
You can have these inspected and possibly replaced to reduce the vibration cominf from your engine.
Hope this helps.
4helpful
2answers
5helpful
2answers
Vibration in Steering Column at Idle
Engine vibration is the cause of this issue, it is the biggest complaint from many owners, changing the engine mounts will help, as mounts age the rubber gets hard and they don't absorb vibration like they should, new mounts help issue, but it will no stop it altogether. A faulty MAF will not cause vibration, just a hesitation on acceleration at times
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
