Hi, have you tried using your computer to format the memory card, what you need to do is put your memory card into a memory card reader then wait a minute then open up my computer then locate the memory card then right click on it with the right button on the mouse then choose format and format it to fat32 then try it in your camera and it should then be working.
if you have been using a memory card in the camera and still have it then put this in the memory card reader and go to my computer and then right click on the memory card and select properties and have a look at what format that memory card is, and if its anything other than fat32 write down what it is. Then put the new memory card into your card reader and goto my computer then right click with the mouse then choose format and then choose to format it to the same type as the other memory card thay you know works in the camera, once you have done this the memory card should work in the camera with no problems.
until you have formatted the memory card to the correct type it wont be recognised by your camera so give it a try what i said and you should find you will have no more problems ok.
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot. try putting a friend's memory card on that same slot. if it works... then your memory card is gone bad... if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
it's in you phone's settings. go to menu then settings (9), go to security (7) and then privacy.. there, you'll see those menus that you'd like to put passwords on. uncheck memory card then press save. put your security code and that's it! you can now use your memory card
Hi!
1st plug in the memory card into the computer. Go to start , then my computer . Locate the drive that has your card . right click on it and format the removable disk. This will clean the mini memory card back to it's new condition.It will also empty it so make sure your files are saved on your computer. Try again to put music on.
Please create a new folder on the memory card and rename the folder to MY MUSIC or MUSIC, now locate the music you want to put them on the memory card and copy them to the card
If this memory card will be connected to a camera you can simply put the memory card to the camera and there you can format it using the camera's menu, you can also format this memory card using a card reader that will be connected to your computer, just put the memory to a card reader then connect it to the computer that way you can also format the memory card....
Well as far as I know you have to connect the memory card into the adapter and connect the adapter to a card reader(a kind of a box like thing which only that can read the memory cards). This card reader you have to connect to the computer and just copy and paste the song and then reconnect
Any probs just let me know!?
