Im not sure what happened all I get is a white screen. The camera still turns on and when you hit the buttin to take oictures it still flashes but nothing shows up. I can take the card out and download them though. Im just not able to see what Im taking or change the settings. How do I fix the problem?
SOURCE: Camera turns off when I try to take a picture!
Try a Re-chargeable higher capacity battery, I hope the problem will not occur again
Raj Thapar
SOURCE: finepixz20 digital camera
That is actually the exact same thing I am experiencing but mine has grey lines on the display window. I was able to take photos to a grey screen connect it to my comp...low and behold my pics showed....I am furious....need some answers as I will never hear the end of it from my daughter.
Grrrrr
weelassy
SOURCE: i have a fujifilm finepix S5000 when camera is
if u see white screen and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
http://www.imaging-resource.com/badccds.html
for support in usa or select different region www.fujifilm.com
http://www.fujifilmusa.com/support/ServiceSupportContact.do
SOURCE: hp L2503a camera, takes pitures, when view on
Hi!
The lens shutter doesn't work. If the cameras is a HP, I believe it's 95% broken shutter cable. Contact your local HP service center.
Hope this helps!
Tom
