From the P4015 manual --
1. In the software program, specify the source tray, the paper size, and the paper type.
2. Send the job to the product. If the tray needs to be configured, a prompt appears on the
control-panel display.
3.If the displayed size is not correct, press the back arrow the correct size, or highlight CUSTOM.
Press the down arrow to highlight
To specify a custom size, first press the down arrow to highlight the correct unit of measure.
Then set the X and Y dimensions by using the numeric keypad or by pressing the up arrow or
the down arrow .
4.If the displayed paper type is not correct, press the back arrow
to highlight the paper type.
Hope this helps.
I am not sure how to get the "Standby mode" back, but one thing you may want to investigate is "JOB STORAGE"
Job storage allows you to send your job to the printer....have the printer wait until you get to the printer and then retrieve your job when you are ready to...This is also great for printing confidential information when you don't want it to just spit out from the printer where there could be someone else around.
See page 162 of the user guide here: http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01436366/c01436366.pdf
for some more details on job storage.
Good Luck
You can set the default paper source for all print jobs. Tray 1 is the default factory settings, only an installed paper source will appear as a menu setting. A paper source selected by a print job will override the Default Source setting for the duration of the print job. Check the word processor print settings, make sure that it matches with the printer paper menu settings. To do this you may click print and click on properties button. Click on the paper tab and you can set the input options like paper size, paper tray (source) and paper type.
For further assistance, please call Lexmark Technical Support.
