TP-LINK 300Mbps Wireless N ADSL2+ Modem Router TD-W8960N Logo
Posted on Mar 28, 2011
Hye. my problem comes by using TP-Link TD-W8960ND 300Mbps Wireless N ADSL2+ Modem Router ( if not mistaken the model number) 1. low internet speed 2. always wireless signal loss...8 hours almost 10times. it give me headache for using internet.always disconnected..what a different N with G if this happen.sighs... Please suggest me what the most extreme configuration for that wireless modem n router to perform on highest / maximum performance.. karl malaysia
1helpful
I can't install
You need to read the manual here.
http://www.tp-link.com/Resources/document/TD-W8960N_V3_User_Guide.pdf
It needs power and the router plugging into the line via the line socket.
A Ethernet cable needs to plugged into one of the WAN ports to configure the router, the other end needed to be plugged into a pc.
I just brought a Tp-link TD-w896ON but the internet speed 1.67 mbps ??
The line speed is controlled by your internet service provider, not by your router. If you have something like AT&T as your internet service provider, then they sell 3 or 4 different line speeds or packages. The cheapest will get you the slowest line speed. So if you have a 300mbps router but you purchased AT&T's cheapest line speed it will never allow you to do downloads, uploads or streams at 300mbps. You gotta Pay to Play. :)
Set up a wireless modem
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Blinking Internet light on frontpanel.
Try to pull the wires and restart your modem if there are no changes you should ask fof techy assistance
PASSWORD FOR D.LINK MODEM MODEL N0 ;DSL-G604T PIN:ISLG604TNAU..C3G
I would suggest that you go through this guide, it will explain you every step which you need to make to get your modem and internet connection back on track:
The ultimate Link Troubleshoot guide: Problems. solutions, PDF manuals
2helpful
Error 045 when setup the modem with Win7 64 bit, connection to network failed.
What the problem? i'm also using this router...
how you setting the router?using wifi or LAN?
BEFORE THAT,
DOWNLOAD HERE
RUN INSTALLER FIRST BEFORE CONNECT TO YOUR ROUTER.
connect line rj11 to link dsl,rj45 to your pc/laptop.(dont use wifi to setup the router)
then plug the power and ON the wifi router.
After that, check light for ADSL, WLAN INTERNET AND PORT(1 OR 2 OR 3 OR 4) IS BLINK
..IF light is okay and blink, then you can setup the utilities.
Is easy. TP-LINK get ready with software that you can setting the router as like professional with the secure encryption. For receiver I'm preferred you using tp-link also. Then you can use QSS function only just click button QSS..
Top TP-LINK Computers & Internet Experts
 Mikey
Mikey
Menachem Grossman
Menachem Grossman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
