Logitech Harmony 550 Remote Control Logo
Posted on Mar 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The remote display say's" Welcome
Anonymous
Level 2:
  • Expert 902 Answers
  • Posted on Mar 26, 2011
Anonymous
Expert
Level 2:
Answers
902
Questions
0
Helped
179627
Points
142
I have the same remote have you run the set up thru the pc yet?
Can't restore "normal" screen. It is stuck in
You might try pulling the AC plug overnight; this could be a simple 'lock-up' of a single circuit and removing its supply voltage may cure it.If this doesn't work, take any digital camera, turn it on and watch the viewfinder (LCD), aim the remote at the camera's lens and press the mode select button. If it is functioning as it should, you should be able to see a white flash occur when the remote's button(s) are pushed. The sensor in cameras is capable of 'seeing' infrared but displays it as a white light.
If the button is dead and you feel adventurous, pop open the remote's case, gain access to the board with the fixed switch contacts and gently clean them with a cotton swab dampened with rubbing alcohol.Also clean the little carbon buttons attached to the remote's keypad, again gently.
Reassemble and try it again.
If the failure is still there, then a circuit (unfortunately probably on the main board if all other functions are working) has failed and the replacement of the main board is fairly pricey.
My remote is not working
Did you try leaving the batteries out for a few hours to ensure it hard resets?
tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 • Televison & Video
1helpful
The readout on the thermostat says "bae lo". I pulled the face of the thermostat off the wall and it reset and I was able to push "run program", but the furnace did not come on.
welcome to Fixya !
here are some steps that you may follow. open the remote and remove batterys or cell of your model for six seconds (i dont know .cause you didnt mensioned the Model.) then place them back.
start the A/C again , see if it works if it doesn't then follow the lower step. and if it helps ignore the rest of paragraph
now open the Air conditioning vent and find the Sensor of the remote near the sensor there shall be a button very small one , maybe its located in a hole. check and observe keenly .
just push that button for once .it will reset the AC. to default
if it doesn't help then comment with a model no
best Regards
I am trying to install a chamberlain wireless keypad opener. I have a Craftsmen door opener. In the instructions, I thought it told me to change on my car remote the DIP Switch for #1 to "-". My...
If you held the smart button in too long it erases the memory and none of the remotes will work. To program it press and hold the button on your remote and then press and immediately release the smart button.
1helpful
Kp-46wt500 sony projection tv says "video 1" on top left corner of screen. how do i get that off?
You will need the original Sony remote that came with the TV.. Push the TV button on the remote and then push the display button on the remote and that should take care of it.. Holler back if you have trouble!
Good Luck!
2helpful
2answers
My logitech 550 is not responding. It has worked
Hi. That message means that there is a button that is stuck down on the remote.
1. Take out the battery, push in and massage each button to ensure it is not stuck down.
2. Put the battery back in, update the firmware,
3. Update the remote.
That should get the remote working again. :)
2helpful
It stopped functioning. Replaced batteries. Nothing. Tried reprograming, firm ware and software update. Still nothing. Screen displays "Welcome to your remote" but no buttons function.
I just got off the telephone with Harmony support with the exact same problem. The rep. indicated that this is usually caused by one of the buttons being stuck. Sure enough, my #1 button was stuck. All is well now. Call 1-866-291-1505 if that does not help.
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
