20 Most Recent Vizio E370VL 37 in. LCD HDTV Questions & Answers
Vizio e370vl 37" LCD TV powers off by itself. It comes on, displays Vizio logo white, then turns off and goes to yellow. We tried unplugging everything for 5mins. Tried changing inputs, no RGB cable c
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
12/25/2017 12:06:47 PM • Vizio E370VL 37... • Answered on Dec 25, 2017
0answers
Do I need a main board or power supply board fot Vizio E371VL HD TV?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
9/23/2016 8:43:30 AM • Vizio E370VL 37... • Answered on Sep 23, 2016
Vizio tv says no signal on any of the hdmi ports
Unfortunately, you fried the HDMI controller. Not necessarily part of the power supply "main board." (Not sure which board is the HDMI controller in your specific TV. It's usually a separate board by itself). Easiest workaround is to use the "Component" cable connectors. The downside is you only get 720P. However, most cable/satellite and _all_ antenna signals are only 720P anyway. Most people only see 1080P when viewing Blu-Ray discs. Aside from replacing the HDMI controller, the cheapest workaround for multiple source connections is to buy an HDMI to Component Converter A/V box, which allows you to connect multiple devices to one box with one set of Component cables connecting to the TV. Then select various "sources" via the box.
4/5/2016 11:22:07 PM • Vizio E370VL 37... • Answered on Apr 05, 2016
I have a Vizio e370vl with no picture but the sound is there?
the back light inverter may be out that's what light the screen
3/3/2015 8:35:50 AM • Vizio E370VL 37... • Answered on Mar 03, 2015
0answers
How to remove front panel
To know more, you have to download its repair manual. It disassemble section will give you more details. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/ Disassemble procedure to many popular brand TVs are given with illustrations.
6/25/2014 10:52:29 AM • Vizio E370VL 37... • Answered on Jun 25, 2014
2answers
What is wrong with the tuner? I can hear audio, but the screen is black.
Hello, I have heard issue similar to this. Possible issues have been bad cable connectors or coax cable. Remove all external connections and see if the problem comes back. If not, then it is external to your TV. If the problem does come back it is possibly in the tuning circuit and will require repair or replacement of the TV. Sincerely, MPKramer I’m happy to help further over the phone at https://www.6ya.com/expert/mark_7bbaa7a1174e0903
5/23/2014 10:38:04 PM • Vizio E370VL 37... • Answered on May 23, 2014
Vizio E370VL 37 in. LCD HDTV Logo
73 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
wrong tuner hear audio but screen
  • Televison & Video
