Dishwashers Logo
Posted on Mar 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water not going into dishwasher model #gsc3404j01ww
Nathan Van Boven
Level 2:
Sergeant:
Champion:
  • Expert 206 Answers
  • Posted on Mar 25, 2011
Nathan Van Boven
Expert
Level 2:
Sergeant:
Champion:
Answers
206
Questions
0
Helped
40232
Points
581
You have a bad water valve
1helpful
Are error codes standard for the same brand/ different models ? Are they standard between brands ? I have a AEG dishwasher model favorit 50879 sensorlogic that gives an error code.
Some companies share generic codes like 'Lw', for low water level or 'DL' for Door Lock. This might help, there are other sites when Googling 'make model error codes'.
AEG Dishwasher Error Codes ' Dr. Dishwasher
www.drdishwasher.com > manufacturer > error-codes
Error/Fault Codes for AEG Dishwashers with an LED Display Fault Code ,10 Symptom: Dishwasher not filling with water. Go to: Why is My Dishwasher Not Filling ...
Water leaking out from bottom of wdf780slybo dishwasher
I think that model had a problem with a clamp coming off the motor reinstall with a new clamp
Wan't take on water after first rinse
see this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
2helpful
No water going in dishwasher...
This sounds like the water inlet is clogged or has failed. For avideo on testing this go to www.appliancehelponline.com/servicemanual.html it's a different model but the testing will be the same.
2helpful
Hello.
The humming sound you hear for the water is the sound of the solenoid trying to open with now success. You will need to replace the water valve. If you get the model number and go to www.sears.com and click parts direct it will have a place to enter the model number and order the water valve for your unit.
ABOUT 1" OF WATER REMAINS IN DISHWASHER
I recently bought two same model dishwashers. Both of them have the same problem. The water leak out of the machine because of the remaining water. I had my contractors come to look at it. They told me that the machines are defective.
The model should be be sold. I am going to have my exchanged to another model.
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Water not going to top shelf in dishwasher
Have you tried cleaning out holes in top rotor, especially the end ones?
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
