This dishwasher is awesome, and cleans better than any I have ever had. Because iit does not have a built-in disposal of sorts, it is imperative that you clean the filter after each use! The little filter holds onto grease and small items, and will easily clog if not cleaned. Every couple of months it is wise to als remove the circular screen at the bottom of the tub in both drawers, as the bottom of these gets coated as well. If maintained and cleaned properly, you will have super clean dishes every time!
Hi I have a D603 dishwasher(fisher and paykel) it started beeping with F1 after I cleaned up inside so I turned off the power source for a while because cant reach the plug it's behind a big fridge so.
Then after that turned on the power source and it stopped beeping but doesn't go power on either...what is the problem??
It sounds like the dishwasher is in flood mode. You would need to dry up the water in the base pan and test. The link below is a video that explains how to repair your fisher paykel dishwasher.
Fisher Paykel Dishwasher Repair Video
