Hello;
The manual for your remote can be found at:
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/RCR461.pdf
Cheers ~
SOURCE: i lost the manual to
A manual does not exist for RCR461. Sorry.
http://66.77.167.109/rcaaccessories/
LG code 1196 works with some RCA Universal remote for power and volume.
SOURCE: i need codeseach for rca remote rcr461
Try eliztech.com. I found it on google and it seems to list codes and manufacturers. Hope it works, I too am trying to get my remote to work. It worked fine for quite awhile and just recently will not, so hopefully this will work..Good luck
SOURCE: i need help on how to install a rcr461 universal
Check out this web site it should solve your problem. http://www.remotecentral.com/features/r-rca.htm
SOURCE: need code for rca rcr461 for sharp tv please help
I don't know if you need 3 or 4 digit codes so i put them both in.
Hope this help's. Instructions on how to insert the codes on the remote are below too.
Hughie.
4digits:
0079
0123
0063
0020
0004
0009
0226
0266
0006
0095
0122
3 digits:
004,
006,
009,
020,
063,
079,
095,
111,
112,
114,
122,
123,
124,
173,
226,
266
1.
Press and hold the SETUP
button until the red
indicator stays on, then
release the SETUP button.
2.
Press and release the
desired Mode button (TV,
VCR, etc.). The red
indicator blinks, then
stays lit.
3.
Enter the 4 / 3 digit code from
the code tables. Note:
after a valid code entry,
the red indicator turns off.
For an invalid code, the
red indicator flashes.
4.
With your device on,
press CHANNEL UP. If
the device responds, no
further programming is
required. Note: If some
buttons do not operate
your device, try one of the
other codes for your
brand.
SOURCE: I need code for rca rcr461 universal remot my tv is a ilo
1. Manually turn on the component you want.
2.Press and hold the TV, DVD etc the illuminated component names turns on.
3.While holding the compnent key down simultaneously press and hold the ON.OFF key - the illuminated name turns off.
4. After holding down both keys for 3 sec, all components name stay on.
5.Release both keys. the component name remains lit.
6.Press and release the PLAY key, wait for 5sec, the component will turn off. If component does not respont continue to press PLAY every 5 sec until component turns off.
7.When the component turns off, then the correct code is blocked. Press REVERSE key wait 2 sec to see if component turns on again.
8. Once component turns on then use STOP key - now code is stored.
Note: use FORWARD KEY AND REVERSE KEY to go front and back on the code search.
(sorry for the typo (if any) I dont have a scanner to scan the manual and I am typing out from the manual)
