20 Most Recent RCA Rcr461 Remote Control Questions & Answers
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
RCA Rcr461... | Answered on Feb 13, 2015
go please to www.fitness.manualsonline.com or www. remotecodelist.com
God bless you
RCA Rcr461... | Answered on Jul 17, 2012
Try there website www.rca.com/codefinder.com
RCA Rcr461... | Answered on Dec 15, 2011
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
RCA Rcr461... | Answered on Aug 19, 2011
The only remotes that turns everything off are satellite remotes.
(Dish Network, Direct TV, Shaw, and Bell)
RCA Televison &... | Answered Yesterday
The one they sent is an older model by 1.
Having said that it is a very minor change so the question is "does this tv have all the functions of the F model and is the picture ok??
Yes it is a smart TV.
RCA Televison &... | Answered 2 days ago
You could use your untill you can find a remote to use ...its easy just check on playstore
Hello, if there are digital audio adapters, optical or coax audio to the RCA, with this adapter, you can exit the TV from the digital output (it can be fiber optic or coax) n you enter the adapter and connect a cable with pair of RCA and the other end of this cable, two RCA also, to the input of your sound equipment
I sent you the link of an adapter
I do not suggest using the headphone output
I hope you can solve your need
Greetings Franco Dosil
Hola, si hay adaptadores de audio digital, ?ptico o coaxial a audio para los RCA, con este adaptador, sales del televisor desde la salida digital (puede ser por fibra ?ptica o por coaxial) y entras en el adaptador y conectas un cable con par de RCA y la otra punta de este cable, dos RCA tambi?n, a la entrada de tu equipo de sonido
Te env?o el link de un adaptador
No te sugiero usar la salida de auriculares
Espero puedas resolver tu necesidad
Saludos Franco Dosil
https://www.amazon.com/Optical-Digital-Converter-Support-Control/dp/B07BKX8BV7
RCA Televison &... | Answered on May 15, 2019
The remote codes are based on the unit the remote is controlling, not the remote itself.
The full list of Remote codes is here
https://www.remotecodelist.com/remotes/rca/rca.htm
RCA Televison &... | Answered on May 10, 2019
rca for assistance
RCA Televison &... | Answered on May 09, 2019
Hello Barbara, I have not been able to find the user manual of your TV Aiwa, nor the one of the Sound Bar, to know if the TV has audio output with the white and red RCA tabs, or what input the Bar has Sound
If you had them on your TV, the white and red RCA tabs, you would have to use an audio cable, with two RCA tabs on one end and on the other, a miniplug 3.5mm connector
The RCA on the TV (Audio Out) and the 3.5mm miniplug connector on the soundbar (Line In)
If you want, you can send a picture of the connections of your TV and another one of the connections of the Sound Bar
I hope you can solve the problem
Hola Barbara, no he podido encontrar el manual de usuario de tu TV Aiwa, ni el de la Barra de Sonido, para saber si el TV cuenta con salida de audio con las fichas RCA blanco y rojas, o que entrada tiene la Barra de Sonido
Si las tuviera en tu TV, las fichas RCA blanco y rojas, tendr?as que usa un cable de audio, con dos fichas RCA en una punta y en la otra, un conector miniplug 3,5mm
Las RCA en el televisor (Audio Out) y el conector miniplug 3,5mm en la barra de sonido (Line In)
Si quieres, puedes mandar una foto de las conexiones de tu TV y otra de las conexiones de la Barra de Sonido
Espero que puedas resolver el problema
RCA Televison &... | Answered on May 06, 2019
RCA Rcr461 Remote Control Logo
Popular Tags
12 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
set
  • Televison & Video
