LG 52SX4D 52" HDTV Logo
Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My LG projection tv (serial number 52sx4d-ub) won't turn on, an orange light flashes then turns red. How do I know if I need to change the bulb or the ballast? And how much does it cost to change the ballast?
Todd Hill
Level 2:
Sergeant:
Champion:
  • Expert 433 Answers
  • Posted on Oct 07, 2011
Todd Hill
Expert
Level 2:
Sergeant:
Champion:
Answers
433
Questions
0
Helped
398954
Points
665
Ck for 350v dc on input of ballast
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Mar 07, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
6823
Points
25
Orange blinking light under a small picture of a light bulb? Then turns to a red light?
Sounds like the same problem I had when I picked up my LG 52SZ8R. After replacing the lamp the TV ran fine.
Easiest way to see if the lamp is the problem is to take it out, and look at the peice of wire in the globe as you would an old light globe.
If you need help, download the following manual, and look at page 9.
http://www.jordansmanuals.com/ServiceManuals/LG/TV/PROJECTION/62SX4R/62SX4R%20Service%20Manual.pdf
If it does come down to you needing to replace the ballast contact: http://www.statewideapp.com.au/index.php?selectedContent=1188381775
They should be able to give you a quote and part number, if you don't like their quote you can always use the part number to search for one thats cheaper.
1helpful
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Lg 52sx4d not starting up
The flashing green bulb light means the access door for the bulb on the lower right side of the TV is open or loose. There are two screws that hold it in. If they are tight, maybe the interlock switch is bad or disconnected. Open the door, and hold in the little white interlock button while turning on the TV. If it still doesn't work, there are wires leading from the switch to a connector about halfway across the TV on the bottom. Connector might be loose. Unfortunately, it is hard to reach. You might have to remove the screws across the bottom rear edge that hold in the chassis and gently slide it out to reach the connector.
6helpful
How to reset after replacing bulb
mute on remote+ok on tv panel at the same time
5helpful
6answers
LG DLP not turning on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bad news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois... you can email me at [email protected]
Lg 52sx4d won't turn on
Need to bring it to services to check to find out the reason. The nearest service. Hope it can satisfy you.
Light bulb flashes 3 times, TV won't turn on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bud news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois
2helpful
5answers
Lg 52sx4d problem
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
No picture-lg ru-52sz51d
Depending on what light is flashing it could be a few things. If the Lamp light (the middle one) is flashing that is problem with or around the lamp. That orange or amber light is an indication that the lamp is reaching the end of its life
If it is the Temperature light (the far right one) then the TV is shutting down because it is over heating and you need to check the cooling fan.
1helpful
TV not turning on
its probably pretty close to time at 18 months and they often give no warning, I believe the orange light on an LG is just the lamp timer which really just counts hours. Pull the lamp out and look at it they often physically break inside and it is obvious
3answers
No picture
set is gone it shut down,call local service dept.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
