I have a brand new lg 42" LH40 and it seems as though the picture is slightly off center with...
(More)
I have a brand new lg 42" LH40 and it seems as though the picture is slightly off center with maybe 2 inches being list on the left side??
standyby light blinks but now power.I have disconned and reconnected everything still the problem...
(More)
standyby light blinks but now power.I have disconned and reconnected everything still the problem persists. There is no sound from the back of TV as in normal standby mode.It's an LG LCD 32" TV.About 4 years old.
the screen is not comig on at all ....but a red light is on and when u hit the volum button the...
(More)
the screen is not comig on at all ....but a red light is on and when u hit the volum button the light turns white ...but still nothing ...please help
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
