Belkin (F5D7230-4) Router (587009) Logo
Anonymous Posted on Mar 04, 2011
1. I'm not sure about the model, the plate says: FSD7230-4 but it has 2 antennas like the FSD7231. 2. How can I configure DynDNS so my file server at home is reachable via internet?
Anonymous
Level 2:
Scholar:
  • Expert 138 Answers
  • Posted on Mar 04, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
138
Questions
0
Helped
47049
Points
422
I wouldn't recommend doing this because it would then be easier for someone to access your files. However, if you wouldl ike to do this, make sure that your fileserver has a static IP adress, and not one handed out by DHCP. Log into your router, and look for a port forwarding setting. Port forward a port such as 5800 to the IP address of the file server. Make sure that port 5800 is open on the firewall on your fileserver. Now go to whatismyip.com and find out what your public IP address is. From the outside world, you can remote desktop into your file server by opening up RDP and typing your ip address such as xxx.xx.xx.xxx:5800
  • Anonymous Mar 04, 2011
    1. I am aware of the risks and I know how to tighten security: apart from a firewall I can encrypt the partition with the data (with GnuPG), I can set file and folder permissions to 0700, I can set the port to something less public than 5800, etc.
    2. I can get my public IP by looking at the GUI of the router.
    3. I think you missed the question: I was asking about how to configure my router to work with a dynamic DNS service like dyndns.com
    Thx for replying anyway.
1helpful
How to set DNS setting
This step-by-step article describes how to install and configure DNS on your Windows Server 2003 computer.
Before You Start loadTOCNode(2, 'summary'); Before you start to configure your DNS, you must gather some basic information. Internic must approve some of this information for use on the Internet, but if you are configuring this server for internal use only, you can decide what names and IP addresses to use.
You must have the following information:
  • Your domain name (approved by Internic).
  • The IP address and host name of each server that you want to provide name resolution for.
Note: The servers may be your mail servers, public access servers, FTP servers, WWW servers, and others.
Before you configure your computer as a DNS, verify that the following conditions are true:
  • Your operating system is configured correctly. In the Windows Server 2003 family, the DNS service depends on the correct configuration of the operating system and its services, such as TCP/IP. If you have a new installation of a Windows Server 2003 operating system, then you can use the default service settings. You do not have to take additional action.
  • You have allocated all the available disk space.
  • All the existing disk volumes use the NTFS file system. FAT32 volumes are not secure, and they do not support file and folder compression, disk quotas, file encryption, or individual file permissions
Install DNS loadTOCNode(2, 'summary');
  1. Open Windows Components Wizard. To do so, use the following steps:
    1. Click Start, click Control Panel, and then click Add or Remove Programs.
    2. Click Add/Remove Windows Components.
  2. In Components, select the Networking Services check box, and then click Details.
  3. InSubcomponents of Networking Services, select the Domain Name System (DNS) check box, click OK, and then click Next.
  4. If you are prompted, in Copy files from, type the full path of the distribution files, and then click OK.
Configure DNS loadTOCNode(2, 'summary');
  1. Start the Configure Your Server Wizard. To do so, click Start, point to All Programs, point to Administrative Tools, and then click Configure Your Server Wizard.
  2. On the Server Role page, click DNS server, and then click Next.
  3. On the Summary of Selections page, view and confirm the options that you have selected. The following items should appear on this page:
    • Install DNS
    • Run the Configure a DNS Wizard to configure DNS
    If the Summary of Selections page lists these two items, click Next. If the Summary of Selections page does not list these two items, click Back to return to the Server Role page, click DNS, and then click Next.
  4. When the Configure Your Server Wizard installs the DNS service, it first determines whether the IP address for this server is static or is configured automatically. If your server is currently configured to obtain its IP address automatically, the Configuring Components page of the Windows Components Wizard prompts you to configure this server with a static IP address. To do so:
    1. In the Local Area Connection Properties dialog box, click Internet Protocol (TCP/IP), and then click Properties.
    2. In the Internet Protocols (TCP/IP) Properties dialog box, click Use the following IP address, and then type the static IP address, subnet mask, and default gateway for this server.
    3. In Preferred DNS, type the IP address of this server.
    4. In Alternate DNS, type the IP address of another internal DNS server, or leave this box blank.
    5. When you finish setting up the static addresses for your DNS, click OK, and then click Close.
  5. After you click Close, the Configure a DNS Server Wizard starts. In the wizard, follow these steps:
    1. On the Select Configuration Action page, select the Create a forward lookup zone check box, and then click Next.
    2. To specify that this DNS hosts a DNS zone that contains DNS resource records for your network resources, on the Primary Server Location page, click This server maintains the zone, and then click Next.
    3. On the Zone Name page, in Zone name, specify the name of the DNS zone for your network, and then click Next. The name of the zone is the same as the name of the DNS domain for your small organization or branch office.
    4. On the Dynamic Update page, click Allow both nonsecure and secure dynamic updates, and then click Next. This makes sure that the DNS resource records for the resources in your network update automatically.
    5. On the Forwarders page, click Yes, it should forward queries to DNS servers with the following IP addresses, and then click Next. When you select this configuration, you forward all DNS queries for DNS names outside your network to a DNS at either your ISP or central office. Type one or more IP addresses that either your ISP or central office DNS servers use.
    6. On the Completing the Configure a DNS Wizard page of the Configure a DNS Wizard, you can click Back to change any of the settings. To apply your selections, click Finish.
After you finish the Configure a DNS Wizard, the Configure Your Server Wizard displays the This Server is Now a DNS Server page. To review all the changes that you made to your server in the Configure Your Server Wizard or to make sure that a new role was installed successfully, click Configure Your Server log. The Configure Your Server Wizard log is located at %systemroot%\Debug\Configure Your Server.log. To close the Configure Your Server Wizard, click Finish.
-----------please let me know if this guideline helps-------------
tip
How to access your home PC files remotely
There are a couple of ways of doing this. Here are a couple of my favourites. All of these require you keep your computer on.
1. Opera Unite
If you install the freeware browser Opera, then create an account with them, you can start Opera Unite, an online service for accessing files and services from anywhere. After you have added the File Sharing application from the Unite sidebar, you can configure the application. Choose to add a share location and choose your main hard drive (generally C:). Then, change your password and make sure that you set your Opera Unite account to private and check that File Sharing is password-protected. Then simply navigate to the URL that Opera provides (generally username.operaunite.com), enter your username and password and then you'll have full access to your files. Note that you will need to keep Opera running on your Computer
2. FTP server. *Only recommended for advanced users
By running a FTP server software like FileZilla on your home computer, you can create a far more powerful file sharing experience. Now, first up, you should go to DynDNS.com, sign up for a free account and then create a Dynamic DNS host. Next, download and install the DynDNS Updater and run on your computer. Now, to access the files that you have configured with your FTP server software, simply use your DynDNS hostname that you created in the sign-in process into Windows Explorer or Internet Explorer (or any browser) with the ftp:// prefix instead of http://. However, if your computer is on a home network behind a router, you will need to configure that also. Set up a port forward (generally Port 20,21, and 23) to the computer running the FTP server. The other advantage to this is that by finding out the server's local IP address (open Run, then type cmd, then type ipconfig, and write down the IP address shown) you can also access the files from the server within your network, simplifying the file access process greatly.
3. Orb 2.0
This is one of the slickest and smoothest methods. Simply download and install the Orb desktop client from Orb.com (also create an account and enter your details into the Orb client), then add any folders you want to share. Then, allow some time for it to index your content. Now, from outside your network, log in to Orb.com with the account you created and click on the Applications button at the top of screen. If you want the music, videos, photos or documents you specified in the setup process, choose the appropriate application, or choose File Sharing to access all of your files at once. Simply navigate the folders as if it was your local computer and you will be able to use them flawlessly. You can even access other physical drives like your CD drive online.
4. TeamViewer
This is a brilliant VNC replacement application. Simply create an account, then install the client on your computer. Also, enter your account details into the client (click the button at the bottom right of screen) and write down your 12-digit ID and password. From here, you have several options remotely. I recommend that you should link up your account first. Navigate to login.teamviewer.com and login, then add a client using the ID and password from your computer. Now, whenever you login to your account, you wont have to remember your ID/password. You can install the client on another computer and connect with your account directly or login to teamviewer.com and use the Java-based applet to connect and use your computer as if you were in front of it.
These should work well when accessing your files.
on Apr 22, 2010 • Computers & Internet
The phone is saying that option 128 is missing im not sure what this means
This means that the phone is expecting to receive a tftp server address from the DHCP server to download it's configuration files, but the DHCP server is not providing this information. Please check with your Systems Administrator to make sure your IP PBX or another server is housing the configuration files and the tftp program or daemon is running, then have them add the tftp server setting to the DHCP scope for your network.
1helpful
I'm pretty good at most computer stuff, but I'm stumped. I'm trying to connect an HPlaserjet5/5m to an HP 170X Print Server on a 16 port dlink switch. I cannot get the hp setup.exe to work off the...
I am not sure if you need the setup.exe file to configure the JetDirect 170x.If you take a look the manual for the JetDirect 170x (http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf) it mentions that this is a "Test" button on the back of the print server. If you press that button when the printer is connect, then it should print out a configuration page. The configuration page will have an IP address that you can browse to with Internet Explorer to configure the JetDirect.
Having a problem getting DynDNS to pass through router and connect to my web server. Web Server can communicate with DynDNS, but an http or https request (ports 80 and 443) do not get to the server. I...
I did this with a cctv and another dns server and does not really work. So i just change my ip to static and open ports 80 and 443 and 8000 (server) and worked fine without using ddns or free dns. Oh and i use this to check my ports if they are working
http://canyouseeme.org/
DDNS with Belkin F5D7230-4
Hi ramwar,
The router is running a query on your DynDNS address and not finding it. You need to make sure that on DynDNS site that you've givin the router the exact and full address. As example. mbase.isa-geek.com would be a full address. On the router it has 3 boxes for the address. It's confusing, but it would look like this. Box 1 mbase box 2 would be isa-geek and box 3 would be .com.
Box 1 is for the name,
Box 2 is the domain
Box 3 is the ext.
Try that.
Good Luck
Mark
P.S. Please don't forget to leave a rating.
DynDns update fails
I have given a ref. configuration for you. If you could provide me the debug results it would be great to help you.
set dns ddns
set dns ddns id 1 server-type dyndns clear-text
set dns ddns id 1 username USERNAME password PASSWORD
set dns ddns id 1 src-interface untrust host-name HOSTNAME.dyndns.org
set dns ddns enable
Then try exec dns ddns id 1
WANT TO CONFIGURE IT
First make sure the PS is hard wired to the router and you have all the wireless settings handy (including the SSID and Wireless Encryption). Then follow the step by step instructions in the file given below: ftp://downloads.netgear.com/files/netgear1/ps104105110inst_eng.pdf Also, the printer with the ethernet cable seems to be a network printer. So, you need to do much to configure it, if its already configured; just connect it to one of the ethernet ports of the PS. Please revert back with any other queries.
DDNS
Currently the only DDNS provider that the DI-604 support is DynDNS.org. When configuring these routers to work with DynDNS.org, please use members.dyndns.org as the Server Address.
Update DDNS automatically
Dynamic DNS (Domain Name Service) is a method of keeping a domain name linked to a changing (dynamic) IP address. With most Cable and DSL connections, you are assigned a dynamic IP address and that address is used only for the duration of that specific connection. To properly configure the DDNS feature follow the steps below: Step 1 Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click on the Tools tab and then click Misc. If you have the DI-614+ with firmware 2.30, click on Tools > Parental Control. Step 3 Enter the required information under Dynamic DNS: Server Address: Enter the IP Address or domain name of your DDNS server (IE members.dyndns.org). Host Name: Enter the Domain name that you registered with your DDNS service provider, (IE mydomain.dyndns.org). Username Password Step 4 Click Apply and then Continue to save your changes.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
