Palm treo i used headset on my palm treo and when i unplugged it the phone was still showing headset attached. Now i can hear caller but they cant hear me with or without headset.
THE phone's Headset Plug is stucked. Try to plug and Un-plug the headset many times for it will release. Best, Play a Music and try this on so when you haer the sound coming from the phone, it means it works
You probably plugged a headset that does not have a mic. after you unplug it your phone will think that the head set is still plugged in. these phones are stupid and after you unplug the headset it will still be looking for the mic. Plug in and out the headset rapidly and then your phone will give you a notice saying that there is no mic to the headset. this will fix your problem. P.S. keep insisting, this fixed my problem
just need a new earpiece speaker or it simply needs to be adjusted into place. If there is no repair shop around you or you do not want to mess with it, then just buy a $20 bluetooth headset to bypass the whole earpiece.
I had to have my Treo swapped once already because of a problem with the headset jack. The same problem is happening now - the phone always thinks the headset is plugged in (even when it isn't). That results in phone ringing (unless on virbate / silent mode) but no audio through the speaker in the back, and no speakphone icon appearing.
Given the symptoms you describe I would go to your service provider and (hopefully) get support under warranty - very likely hardware related.
Taking the battery out to switch your phone ON/Off can cause serious problems. -------------------------------------------
To receive calls, your phone must be on.
This is different from having only the screen turned on (see Turning your phone on). When your phone is off, your calls go to voicemail. To see a picture of the person calling you!
Learn how to assign a caller ID picture in Assigning a caller ID ringtone. If music is playing when a call arrives, the smartphone rings softly. You can answer the phone as you normally would. The audio pauses during your call. To answer a call, do one of the following:
• Press Phone/Send .
• Press Answer (left action key).
• If the headset is attached, press the headset button.
To ignore a call and send it to voicemail, press Menu (right action key) and
select Ignore or press the Power/End key. -------------------------------------------
Waking up the screen and turning it off. Wake up the screen and leave the phone turned off when you want to use only the organizer features of your smartphone, for example, when you’re on a plane and want to look at your calendar. You can also turn off your smartphone’s screen without turning off your smartphone’s wireless features. You can turn your screen on and off by pressing Power/End.
Taking the battery out to switch your phone ON/Off can cause serious problems. ------------------------------------------- To receive calls, your phone must be on. This is different from having only the screen turned on (see Turning your phone on). When your phone is off, your calls go to voicemail. To see a picture of the person calling you! Learn how to assign a caller ID picture in Assigning a caller ID ringtone. If music is playing when a call arrives, the smartphone rings softly. You can answer the phone as you normally would. The audio pauses during your call. To answer a call, do one of the following: • Press Phone/Send . • Press Answer (left action key). • If the headset is attached, press the headset button. To ignore a call and send it to voicemail, press Menu (right action key) and select Ignore or press the Power/End key. ------------------------------------------- Waking up the screen and turning it off. Wake up the screen and leave the phone turned off when you want to use only the organizer features of your smartphone, for example, when you’re on a plane and want to look at your calendar. You can also turn off your smartphone’s screen without turning off your smartphone’s wireless features. You can turn your screen on and off by pressing Power/End.
