Mitsubishi WS-65713 65" Rear Projection HDTV Logo
Posted on Jul 29, 2008
Capacitors on DM Module
I have called tech support and they seem about as confused as an Amish Electrician, LOL. I figure off Im better off trying to get help on here as the local TV repair shop wants to charge $150 just to come out to my house to tell me whats wrong with the television. I have an issue with the blinking green timer light flashing in the front and the tv wont power up. I have read people on here talking about the 4 capacitors on the DM module, but I need to know where this is located and how to check the capacitors. If it's easy enough I would rather just replace them myself. Also where is the best place to order these capacitors if they need to be replaced.
Thanks,
Roger I just got the blinking green light and want to attempt to fix this problem myself.  I do not want to break anything on the WS-65713 so i just want to make sure i know what the dm board looks like before i take anything apart and make sure i can locate the capacitors (the exact capacitors and quantity) for this television. thank you very much for your time and help
Kenny Patel [email protected]
  • rfischer7 Nov 22, 2008
    I have the same blinking light problem on my own WS-65713. If someone could email me the repair instructions, I would greatly appreciate the help. My email is [email protected].
    Thanks in advance for your help!
  • David_Gar387 Dec 21, 2008
    Hi, my bro has the same problem, can you please email us the instructions?
    Thanks,
    Dave
    [email protected]
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Nov 08, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
1117
Points
8
I just fixed the capacitors on my WS-65713. I can email you instructions with pictures if you wish. You will need to de-solder and solder on new capacitors but if you check out video instructions on utube you should be okay with some practice.
Constant blinking green light on Mitsubishi WS-65909 TV. Replaced the 7 Capacitors on the DM module and re-installed into the tv, plugged in and the same blinking green light problem is happening. Is
This is a V19 chassis, circa 2002
If all capacitors were replaced correctly & all caps with bulging tops were replaced, It sounds like you may have other issues on the DM pcb. Possibly defective ICs. That would be the E2P module (a small pcb which plugs directly onto the DM pcb), which is specific to your particular model & serial#
Several years ago the only way to get the E2P, was thru the manufacturer, they also, used to make a kit that you could replace those ICs yourself. Those pcbs & kits were limited. So all I can do is wish you much luck if that is the problem.
At this point I would double & triple check the replacement of your capacitors.
2answers
We lost power the other night. Now I have a continuous green blinking light and it won't turn on. I have tried everything the manual says.
Try Going To The Mitsubishi Web Site. Downloading The Mitsubishi Service Manuals If You Don't Already Have It. It Will recommend The parts You Need To ordering. Circuit board photos are also shown which provide a visual reference during the repair process.
If you decide to have a service technician do the repair, insist that the "DM" module is removed from the TV and ONLY the four 1000uF, 16V Capacitors (Caps) located on the DM Module are replaced. MOST techincians will INSIST on replacing the entire DM Module and not simply the capacitors. The cost is about $200 for a technician to replace the capacitors and $1000 for replacement of the DM Module. As you will read below, doing the repair yourself will cost less than $4.00 for the 4 Caps.
Need a wiring scematic to locate the dm module to replace caps for the microprocessors. Had a power outage the other night now the power light on the front of the set just blinks. Can anyone help me?
You need pictorial to locate dm module in tv and to replace bad capacitors.
This Link will help you to locate dm module in tv and info about what are requirements to replace bad capacitors in dm board.
Hope this will help you.
Thanks.
1helpful
7answers
I have a Mitsubishi 62" DLP and all it does is blink fast green from the timer for 1 minute. I checked the lamp and ballast board and both are good.
Power supply board Look for vented or puffed up on top capacitors 1000uf16v.330uf 10v, 470uf 16v.
Also what is the model number printed on back of TV?
2helpful
Timer flashes, then lamp light comes on. Unit will not turn on. Lamp not blown.
DM module is not booting up because there are some capacitors in its power supply that are defective in your tv .There are four capacitors that go bad inside your tv in DM module . You need to replace those 4 capacitors . It will cost you around $40 . If you're not a tech, and you'll most likely need to call technician to repair your tv . Hope this helps .
1helpful
2answers
Mitsubishi dlp projection tv timer flashing green unable to reset TV
call Mitsubishi, 18003322119. They seem to know this is a ubiquitous problem with these sets, and seem willing to cover parts (all new electrical chasis), but not labor. Have to have an authorized repair tech look, verify problem, fax info to Mitsubishi, then will send in chassis for rebuilt one. Cost from what I've seen runs $300-400 in labor. Stinks you have to pay any, since Mitsubishi used bad capacitors in making the T.V. in the first place.
1helpful
Mitsubishi TV WD-52528 green flashing light
IF the lamp has already been tried here with a known good one....then...
Most like the "DM module" needs to be replaced. This is NOT a cheap repair and Mits KNOWS these sets are a problem. There is SOME possibility that the DM module, and possibly the formatter module too--could be repaired, about a 60% chance or so, by a decent tech...IF there is one in your area that will work on these sets. If you can get someone to check it out. ....have them chack for "bad capacitors" on ALL THREE of these modules::
The DM module.
The "formatter" module
The power supply.
Often--about 10 new caps on these three modules WILL fix the set. But it is a VERY time-consuming affair, as the modules are in a BUNCH of shields and such, so...figure on 3 hours of work, perhaps the tech removing the modules--or TV--from your house, and repairing the modules, and returning. A fair price to do this.... (if you don't have a service plan...if you do...someone SHOULD be willing to come out from warranty service and do this...) IF the modules can be re-capped--would be about 450-500, depending on the trip distance and such.
if the modules cannot be repaired /about 1in 3 times...and you have a warranty..and mits cannot supply new ones...you might just get a new set. This happened a NUMBER Of times last year, where I was at.
I have a Mitsubishi WD-62725 with the ''blinking green light of death.'' I got this T.V. for free so I figured might as well try to repair it myself (and can I just say did Mitsubishi really have to make...
It's definitely the one causing the problem but I suggest you also replace or resolder the 4 capacitors on the DM board to make the job at once. Just make a note on the polarity markings of the capacitors and the board. If there's no indicated polarity markings on the board then nevermind. Here's what you need to do the job:
  1. Soldering iron
  2. Desoldering pump
  3. Soldering lead
Steps:
  1. Heat up the soldering iron
  2. Melt the lead on the board with the soldering iron and use the desoldering pump to remove it and loosen the terminals of the capacitor.
  3. Remove and replace the capacitors one at a time to avoid confusion.
  4. Make sure to make a good solder. A good solder is volcano-shaped.
  5. Cut any excess lead terminals.
  6. Make sure there's no stray leads that might cause short circuit on the board.
  7. Check the terminals of the newly installed capacitors for any short circuit.
Tip:
The board experiences vibrations during the operation of the unit. These vibrations can result to broken solders as the time passes by. Before re-installing the board, check it for any loose or broken solders and resolder as a preventive measure. A magnifier will surely help.
1helpful
Tv tries to start green light comes on then shuts off
Call a good TV Tech and tell him to replace the Capacitors in the DM Module. There are some 2200uf and some 1000uf at 16 volt capacitors that should be upgraded to 25 volts instead of the original 16 volts. This is a common problem for the V21 Mitsubishi Chassis.
Wont power up , green indactor light wont stop flashing
You have four capacitors bad on the "DM" module in the unit. I recommend you get a tech to do this repair. This is due to the complexity of accessing the DM module. A qualified tech can do this repair in under an hour. You can find a tech in your area by inputting your zip code on the home page of this website. Let me know if I can be of further assistance
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
