Computers & Internet Logo
Walter Willis Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dvd drive not recognized - LG DRN-8080B DVD Drive
Shahzad Waseem Akbar
Level 3:
  • Master 746 Answers
  • Posted on Feb 26, 2011
Master
Level 3:
Answers
746
Questions
0
Helped
272408
Points
2750
Check your CD/DVD data cable from mother board, if it is cracked please change it.
Good Luck
1helpful
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
2answers
Does not recognize dvd drive
When you click Start/My Computer is the DvD drive shown as one of your devices? If not then try the steps below:
Remove the Power Cord, Remove the Battery, turn the laptop over and remove the one screw that secures the dvd drive and pull the drive out. After 20 seconds plug the DvD drive back in, and then try booting to see if it is recognized. If the drive is not recognized then you will have to remove upper and lower filters.
If you are talking about the drive won't play a dvd then that's another issue. Most times computers have a hard time playing something that was created by someone else. Try a store purchased DvD and see if it recognizes and plays it.
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
3helpful
2answers
Dvd drives play CD's but no longer plays DVD's
Hi there!
May be a corrupt driver issue.
Go to your device manager/DVD drives/right-click & uninstall. Restart machine & let windows look for the drivers & install them.
Pls send us your feedback as it's very important for us. Good luck!
1helpful
Doesn't recognize cd or dvd disk when inserted in
acer 4520 doesn't recognize cd or dvd when inserted in disk drive
Dvd-rom sd-616E driver no longer recognized by
Reboot the computer and go into the BIOS, see if its recognized in there, if its not recognized then you'll need to turn the computer off and unseat and reseat the cable and the power connector to the dvd drive. Then turn on the computer again and go into the BIOS, if the dvd drive is still not recognzied then you'll need to replace the drive.
If the dvd drive is recognized in the BIOS and not in windows then you'll need to go into the system restore in windows and choose a date the last time the computer was working, it will restore your computer back to this date and reboot. At that point it should recognize your dvd drive. If it doesn't then your OS is corrupt and you'll need to wipe out the drive and restore your computer back to factory defaults.
Computer not recognizing Dvd drive
Hi, Check the MS word / software file it works DVD drive, if it recognize there is no problem the drive and play CD - format files.
If not recognize, i found that DVD Lens not working what you can do DVD lens cleaner disc you found stores. Rgds, Manju
I cannot get my DVD Rom drive to recognize any DVD
You need to install the DVD decoder that came with the drive such as PowerDVD or WinDVD. If you dont have the disks or setup files for those, you can download a free Windows DVD player program such as VLC Media Player that will work. http://www.videolan.org/vlc/
Do not recognize any cd/dvd in dell vostro 1510 bios A13
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7
find me a solution
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
