You mean the camera doesnt turn on??...IF changing the batteries dont give any effect on the camera then there can other problems..Better take it to any service centre for a good service!!..Thank you....
Check that the contacts are clean and they all connect well.
is the camera still underwarranty? incase it is not a problem with the contacts it maybe a fault in the mainboard, best to send in for service incase cleaning the contacts and trying a few difrent types of batterys has no effect.
If its out of warranty the repair may cost, I can recommend advance camera
www.advancecamera.com
Check that there is no oxide in battery contacts
Check first that there is no oxide or liquid covering battery contacts, try also too see if battery contacts are broken.
Ensure you are using alkaline batteries (duracell etc.), this camera does not start with standard batteries.
Check that the battery cover is closing properly.
If it still does not give any sign of life then it is either a broken contact on battery or a faulty board. In both case you will need to take the camera to a repair shop, as it must be taken apart and some part replaced.
Check if guaranty if still valid.
