Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=841267
Generic problem for all Vacuums
How to change belt on
Posted by tbellme on July 27, 2008
How to change belt on Hoover Turbo 4600
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
