Hi
--- Please dont forget to vote this answer was helpful and accept it. Many thanks ------
If you have the machine powered on and on button on.
The only other thing is to ensure is the door is fully closed as there is a safety interlock on the door.
Try pressing the door firmly but harder and see it machine starts.
SOURCE: hi - i have a
The hose may be partially blocked, stopping the air from blowing through properly,check that there is no bend and that the hose is not sagging down as this causes the moisture laden air to condense inside the hose and create water build up.
The water has probably caused the thermostat or heater to fail.
To check the element and stat(s) you need to remove the rear panel of the dryer, and tyest with a meter.
Plz rate my solution.
Thanks.
SOURCE: the belt is broken on my creda tvr2 tumble drier
If you are in the U/K, then got www.hotpoint.co.uk, and follow the links.
Please rate my solution.
Thanks.
SOURCE: Snapped belt
Watch the video and it will give you the idea, it may be a different model but it's all about the same to replace.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: My creda tvr2 only spins one way.. does anyone
sounds like a timer fault, the reverse contacts in the timer are not making contact.
