Cyberhome DVR 1600 DVD Recorder Logo
Posted on Feb 15, 2011
When I insert a DVD it says No disc - Cyberhome DVR 1600 DVD Recorder
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Feb 15, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1034
Points
6
This is caused by an open (or bad) 10UF capacitor in the power supply. The voltage rating on this cap is too low, consequently, many units suffer the same problem. I replaced my with a 15Volt cap and the unit has been working for over 2 years now.
Gives insert disc message when disc already inserted
the DVD tape you inserted can't read by your DVD player, try to use lens disc cleaner if not fix, LASER problem.
tip
How to copy DVD Movie on Mac OS X?
This step-by-step guide is dedicating to demonstrate how to backup DVD movie (copyright protected included) to computer and copy DVD to a new DVD disc with no protections on Mac OS X (leopard included)
The tool you need is Aimersoft DVD Copy for Mac, which you can download for free from here.
It’s very easy to use, just with three simple steps then you can easily copy DVD on Mac.
Step1. Select DVD Source
After you install and lunch Aimersoft DVD Copy for Mac, put the DVD disc into your DVD drive. Click the “Select Source” drop-down list to browse your computer and located your source DVD movie (either in a folder or from your DVD-ROM).
Step2: Select DVD Copy Method
Aimersoft DVD Copy for Mac allows you to back up DVD to a folder on your hard drive or directly copy DVD to a new DVD disc. In the “Select DVD Copy Method” field, select a method to output the selected DVD movie according to your need:
If you want to back up your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly copy your DVD movie to a new DVD disc, you can just select the DVD Burner where you have inserted a blank DVD disc.
Note: If you are copying a DVD disc from your DVD Burner to a new DVD disc, Aimersoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
But if you have two or multiple DVD Burner, you just need to change object DVD to another DVD burner and insert a blank disc into it , then Aimersoft DVD Copy for Mac will automatically copy DVD movie to the new DVD disc. No need to wait for the conversion to insert a new blank DVD disc.
Step3: Program Settings (optional)
Set Buffer Directory: Specify a directory on your hard drive as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard drive that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step4: Start Copying DVD
After all things done, click the Start button to start copying your DVD movie or burning it to a new DVD disc. That’s all.
on Feb 10, 2010 • Computers & Internet
Everytime I put a disc in I get an error saying no disc
Does the disc you insert are original..If not is isn't posibbles for your dvd player to not recognize yor disc cause most of the branded dvd players like you have didn't read pirated disc..but if the disc you insert is original. Try to clean your dvd player using a dvd disc cleaner.
2helpful
SD-P1900SN After inserting movie DVD, I get message, "No Valid Disc". I ensure disc is inserted properly. Bought player a couple of years ago. Have only used it 3 times. Can't find anything in manual...
Check for cracks or scratches on the dvd disc?It a dvd movie disc,not a computer program dvd disc?Take the dvd disc,washes it with some dish washing soap.To clean all the grims and grease out of the dvd disc laser surface to the dvd player laser eye to read the dvd disc.
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
1helpful
Dvd player does not load when a disc is inserted
Check ur DVD for smushes,scratches and cracks?
4helpful
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
2answers
Problem in philips dvd
IT WILL SHOW NO DISC IF THE DVD IS HIGH DEFINITION AS THIS PLAYER IS NOT HD CAPABLE.
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
