Sony VPH D50HTU Multimedia Projector Logo
Posted on Feb 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a SONY VPH-D50 projector. Screen has green tin to it. I covered 2 of the 3 bulb to see image quality of each and it appears as though there is no image projecting from the Blue. I can look into the lense and see the image inside, but it will not project out onto the screen.
Anonymous
Level 3:
  • Master 699 Answers
  • Posted on Feb 09, 2011
Anonymous
Master
Level 3:
Answers
699
Questions
Helped
218594
Points
2363
You will probably need a new lamp.
Please dont forget to vote if you liked my answer
thanks
Tv screen is green and bulb has been replaced
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Sony VPL-P510 projector
there are 3 LCD panels in the projector.
red panel,green panel and blue panel
I seems that the red panel is failing
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Sony projector xga indicate lamp cover
there is an conductor under the cover,
pls push it down ,
and turn on the projector
Have a nice day!
Jerry
Lampdeng Limited
1helpful
MY VIDEO PROJECTOR SONY VPL -HS10, CONNECTED TO COMPONENT VIDEO OUTPUTS IS DIPLAYING DATA ON THE SCREEN UPSIDE DOWN. HOW DO I CHANGE THIS PLEASE
There should be a menu option for orientation. The selection may be for ceiling vs standard. You have the unit set for ceiling mount.
Dan
1helpful
2answers
I have an Mitsubishi X490U Multimedia Projector - it hangs inverted in our church auditorium. The image on the screen looks okay with bright images projected, but dark images appear to look green...
This unit needs a new Optical block, most likely more than a new projector
check out projectorsuperstore.com for a replacement
by the way, your $10,000 projector only has 2600 lumens, a new/refurbished unit will have 4000 lumens for less than 25% of the cost of your unit
Green screen projection
This is the exact same issue as I described for an Epson user. So I'll repeat it here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the green color has gone out. The image is made up of red, green and blue images layered upon the screen. If the green panel has gone out then there is nothing filtering out the green light in the image. This causes a nice green hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Wondering if moisture can mess up a projector
Absolutely. The circuitry can "short out" on the controller boards.
A Pelican watertight case or similar is your best best.
They're not too expensive... but a new projector is more expensive.
Here's their site with different models available.
http://www.pelican.com/case_category.php?CaseSize=%&New=%
Best Wishes.
Erro code 35
what is the exact model of your Sony projector to give you help.
1helpful
2answers
Sony HS10 error lights
you could try a new lamp, some lamps fire, but do not stay on
Sony g70
this problem from section chek your card
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
